[OpenLayers-Users] Questions about Markers and Text markers
Miguel Chang
mac_luzer at hotmail.com
Wed May 25 11:13:05 EDT 2011
Hello there,
Yes, I get your idea but in the demos I've seen so far there is only one way to load a batch of markers and it's by using a textfile I've not seen another way to do so unless I code a lot of jscript...
Date: Wed, 25 May 2011 10:29:47 -0500
Subject: Re: [OpenLayers-Users] Questions about Markers and Text markers
To: mac_luzer at hotmail.com
CC: openlayers-users at lists.osgeo.org
My guess would be that one way to approach this would be to have an XML file of your preference loaded into the side-bar and map at the same time. If you set a listener to the list-item and it's related feature, you should be able to get the functionality you're describing. Someone may have a more detailed solution.
On Wed, May 25, 2011 at 9:48 AM, Miguel Chang <mac_luzer at hotmail.com> wrote:
I want to show a sidebar with the information of the markers, kind of list where I could sort the data by date or by location and by selecting this list it directly shows me the position on the map.
> From: n.e.kendall at gmail.com
> Date: Wed, 25 May 2011 00:49:34 -0500
> Can you clarify what you're trying to do? By definition if you want to mess with the text on the client side you'll need jscript...which is what ol does.
> Sent from my mobile device
> On May 24, 2011, at 11:28 PM, Miguel Chang <mac_luzer at hotmail.com> wrote:
> > Hello there, I´m implementing a web page using Openlayer as the map provider and so far it seems to work... but I have some troubles with the markers because I want to show the information both at the map and on the page itself, is there anyway to manipulate the data from text file once loaded? also I´m looking for a more direct approach on feeding the data, like extracting directly from a database, is there any implementation that does not involves a lo of javascript coding ?
> > Users mailing list
> > Users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110525/500b28ba/attachment.html
