[OpenLayers-Users] Questions about Markers and Text markers
Nicholas Efremov-Kendall n.e.kendall at gmail.com
Wed May 25 11:53:24 EDT 2011
Miguel,
I think you either need to tell us a little more about what you're trying to
do, or go back to the basics of web programming. OpenLayers is a Javascript
library. How you store the GIS data on your server and how you deliver it to
OL is up to you. You can use proprietary software, like ArcGIS server, or
free stuff like mapserver, geoserver, etc. You can also write your own GML
files. However, all of those options will still require you to customize the
output in the client via javascript, there's no way around that I'm afraid.
This list is primarily for people who are working with javascript. So, if
you can tell us more about what you want to do we can be more helpful.
Complaining that there's a lot of javascript to write on a
javascript-library user's list is counter-productive to helping you.
On Wed, May 25, 2011 at 10:13 AM, Miguel Chang <mac_luzer at hotmail.com>wrote:
>  Hello there,
> Yes, I get your idea but in the demos I've seen so far there is only one
> way to load a batch of markers and it's by using a textfile I've not seen
> another way to do so unless I code a lot of jscript...
> Date: Wed, 25 May 2011 10:29:47 -0500
> Subject: Re: [OpenLayers-Users] Questions about Markers and Text markers
> From: n.e.kendall at gmail.com
> To: mac_luzer at hotmail.com
> CC: openlayers-users at lists.osgeo.org
> Hi,
> My guess would be that one way to approach this would be to have an XML
> file of your preference loaded into the side-bar and map at the same time.
> If you set a listener to the list-item and it's related feature, you should
> be able to get the functionality you're describing. Someone may have a more
> detailed solution.
> On Wed, May 25, 2011 at 9:48 AM, Miguel Chang <mac_luzer at hotmail.com>wrote:
>  I want to show a sidebar with the information of the markers, kind of list
> where I could sort the data by date or by location and by selecting this
> list it directly shows me the position on the map.
> > Date: Wed, 25 May 2011 00:49:34 -0500
> > Can you clarify what you're trying to do? By definition if you want to
> mess with the text on the client side you'll need jscript...which is what ol
> does.
> > Sent from my mobile device
> > On May 24, 2011, at 11:28 PM, Miguel Chang <mac_luzer at hotmail.com>
> wrote:
> > > Hello there, I´m implementing a web page using Openlayer as the map
> provider and so far it seems to work... but I have some troubles with the
> markers because I want to show the information both at the map and on the
> page itself, is there anyway to manipulate the data from text file once
> loaded? also I´m looking for a more direct approach on feeding the data,
> like extracting directly from a database, is there any implementation that
> does not involves a lo of javascript coding ?
> > > _______________________________________________
> > > Users mailing list
> > > Users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110525/ac667bfe/attachment.html
