[OpenLayers-Users] Questions about Markers and Text markers
Michael
mdm at yachtpc.com
Wed May 25 11:35:27 EDT 2011
In my application, each time I add a feature of the type I want listed,
I add a call to a javascript function (jquery, actually) that adds it to
my list on the side.
There are many pre-existing scripts for sortable tables and the like,
but there will be some javascript coding.
An alternative would be to render the page with a mixture of js and PHP,
where PHP (or some other server-side language) queries the database and
spits out properly-formatted web page elements. I'm doing that right
now and can say that at the end of the day you end up looking at as much
javascript as you would have otherwise. But I got it to work, so that's
something.
Whether you use XML or JSON or .csv or (as I do) a rendered .js file to
transfer the data to the web page is a matter of design choice.
Michael
On 5/25/2011 7:48 AM, Miguel Chang wrote:
> I want to show a sidebar with the information of the markers, kind of
> list where I could sort the data by date or by location and by
> selecting this list it directly shows me the position on the map.
> > CC: openlayers-users at lists.osgeo.org
> > From: n.e.kendall at gmail.com
> > Subject: Re: [OpenLayers-Users] Questions about Markers and Text markers
> > Date: Wed, 25 May 2011 00:49:34 -0500
> > To: mac_luzer at hotmail.com
> > Can you clarify what you're trying to do? By definition if you want
> to mess with the text on the client side you'll need jscript...which
> is what ol does.
> > Sent from my mobile device
> > On May 24, 2011, at 11:28 PM, Miguel Chang <mac_luzer at hotmail.com>
> wrote:
> > > Hello there, I´m implementing a web page using Openlayer as the
> map provider and so far it seems to work... but I have some troubles
> with the markers because I want to show the information both at the
> map and on the page itself, is there anyway to manipulate the data
> from text file once loaded? also I´m looking for a more direct
> approach on feeding the data, like extracting directly from a
> database, is there any implementation that does not involves a lo of
> javascript coding ?
> > > _______________________________________________
> > > Users mailing list
> > > Users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110525/5fbcd03b/attachment.html
