[OpenLayers-Users] Javascript - Functioncall: strange behaviour
Marc Jansen
jansen at terrestris.de
Tue May 31 16:17:33 EDT 2011
Hi Harry,
just guessing, but does IE show anything when you set the options-value
as well as its text? Try to add
sbox.options[x].value=streetlist.features[x].properties.Adresse;
after
sbox.options[x].text=streetlist.features[x].properties.Adresse;
As I said, this just a guess.
Regards,
Marc
Am 31.05.2011 13:12, schrieb Budschedl Harald:
> Hi folks
> I have a not strictly OL related problem concerning a function call
> which works in FF, Safari, Opera, etc ... but does not work in IE (7
> and 8)
> Let me tell you what I try to do.
> 1st step:
> An ajax control fills a selectbox with adresses. The webservice
> delivers geoJSON btw. The serializing of the JSON-Object (streetlist)
> and the filling of the selectbox (sbox) looks like this:
> streetlist = eval('(' + httpRequest.responseText + ')');
> //alert(streetlist);
> sbox =
> document.getElementById('straSel');
> sbox.length=streetlist.features.length-1;
> if
> (sbox.length<=0) {sbox.length=1}
> for(x=0; x< streetlist.features.length-1; x++){
> Everything works out fine. The Ajax works, the Selectbox is filled,
> all of this works fine in all the browsers.
> So now we have a Selectbox, filled with Adresses.
> 2nd step:
> From my selectbox, I select one entry and klick on the "get me
> there"-button to call a function "goThere" which will find the
> appropriate X and Y coords from the geoJSON Object and zoom the map to
> there.
> The Selectbox and "get me there" Butto look like this:
> <p>
> <select id="straSel" name="straSel" size="5" >
> <option id="straOpt">Click result ...</option>
> </select>
> </p>
> <input type="button" value="get me there" onclick="goThere();" />
> The function looks like this:
> function goThere() {
> // gets XY coordinates for selected
> entry and zooms there
> var adressX;
> var adressY;
> var selbox
> =document.getElementById('straSel');
> var selIndx=selbox.selectedIndex;
> selectedAdr=selbox.options[selIndx].value;
> //alert(selbox.options[selbox.selectedIndex].value);
> alert(" At index"+selIndx+" in the
> box, there is "+selectedAdr);
> if (streetlist) {
> for(x=0; x<
> if
> (streetlist.features[x].properties.Adresse == selectedAdr) {
> adressX=streetlist.features[x].geometry.coordinates[0];
> adressY=streetlist.features[x].geometry.coordinates[1];
> //alert(selectedAdr + '___X=' + adressX + '___Y=' + adressY);
> map.setCenter(new
> OpenLayers.LonLat(adressX,adressY),allScales[1],false,true);
> break;
> I also tried to deliver the Adress itself in the function call, but
> this doesn't change anything.
> The function works fine in Firefox
> It works fine in Safari
> It works fine in Opera.
> Heck, it even works fine on my Palm Pre Plus...
> Just IE (7 and 8) does not do ANYTHING. I found out (using the alert
> statements) that the value is always empty in IE.
> Has anyone an idea what's the problem?
> TIA!!
> Harry
> IKT Linz GmbH
> Ein Unternehmen der Stadt Linz
> 4040 Linz, Hauptstraße 1-5
> AUSTRIA
> _ ________________________________ _
> Diese Nachricht inklusive aller Anhänge kann vertrauliche
> Informationen enthalten. Sie ist ausschließlich für die adressierten
> Personen bestimmt. Das unerlaubte Kopieren sowie die unbefugte
> Weitergabe sind nicht gestattet. Sollten Sie nicht die richtige
> Adressatin/der richtige Adressat sein, vernichten Sie den gesamten
> Inhalt (§ 93 Abs. 4 Telekommunikationsgesetz 2003) und informieren Sie
> bitte sofort den/die Absender/in. Nähere Regelungen zur elektronischen
> Kommunikation mit der Stadt Linz finden Sie in den "Allgemeinen
> Hinweisen und Nutzungsbestimmungen betreffend das E-Government der
> Stadt Linz (e-linz)" ( http://www.linz.at/images/AGB_egov_2008.pdf )
> IKT Linz GmbH, Firmenbuch des Landesgerichtes Linz ++
> Firmenbuch-Nummer: 321197z ++ UID-Nummer: ATU64636344
> IKT Linz Infrastruktur GmbH, Firmenbuch des Landesgerichtes Linz ++
> Firmenbuch-Nummer: 321990s ++ UID-Nummer: ATU64664303
> A-4020 Linz, Gruberstraße 42, Tel. +43 732 7070 0, Fax: +43 732 7070
> 54 1555, office at ikt.linz.at, www.linz.at/ikt <http://www.linz.at/ikt>
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110531/c882e284/attachment-0001.html
