[OpenLayers-Users] Moving marker dynamically on mouse click.
Carsten Eider eider at fh-bingen.de
Sat Nov 5 03:02:14 EDT 2011
I solved a similar issue with a different approach:
When clicking onto the map the old marker was removed from its layer and
a new one was set.
For my luck, there was always only one marker in the layer.
- Carsten
Am 05.11.2011 00:58, schrieb Jongsuk Lee:
> Hi, I am using 2.1.1 release library and I am using with bing layer.
> I am trying to do marker to move according to user's mouse click.
> So old marker should move accroding to new click location. I am using
> moveTo method in marker object.
> This seems to work fine when I change zoom but once I pan viewport,
> position gets hairy.
> Do I have to keep track of pan viewport movement and offset il?
> am I not understanding api correctly? I tried on ie9 and latest chrome
> and that shows same behavior.
> Any tips would be appreciated. Thanks for awesome library.
> jong.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
