[OpenLayers-Users] How to draw horizontal/vertical lines in
openlayers?
aridbh
aridbh at yahoo.com
Mon Nov 21 15:15:47 EST 2011
I am using openlayers and able to draw lines using DrawFeature and
OpenLayers.Handler.Path. Now I need to provide an option to be able to draw
horizontal/vertical lines. Which means when the user starts drawing line and
moves the mouse to an angle, if the angle is less than 45 degrees to the x
axis it will draw only horizontal and if the angle is more than 45 degrees
it will start drawing vertical lines.
Any ideas on how to do this?
Thanks,
Aridbh.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-draw-horizontal-vertical-lines-in-openlayers-tp7017796p7017796.html
