[OpenLayers-Users] need a clarification re styleMaps
Puneet Kishor punk.kish at gmail.com
Tue Oct 4 11:42:36 EDT 2011
The following code works
    // Add styleMap to layer
    var style_map = new OpenLayers.StyleMap({
        externalGraphic: uri + "/img/arrow.png",
        graphicWidth: 15,
        graphicHeight: res[0].height,
        rotation: res[0].angle
    var lyr = new OpenLayers.Layer.Vector("name", {styleMap: style_map});
    // Points without styleMap
    var points = [];
    points.push(
        new OpenLayers.Feature.Vector(
            new OpenLayers.Geometry.Point(res[0].lng, res[0].lat)
    lyr.addFeatures(points);
    map.addLayer(lyr);
everything works. Different points get drawn with symbols of correct height and rotation. But, if I don't add the styleMap definition to the lyr when creating it, and instead, add it to the point, like so
    // Layer with styleMap
    var lyr = new OpenLayers.Layer.Vector("name");
    // Add styleMap to each point
        graphicWidth: 15,
    var points = [];
    points.push(
            new OpenLayers.Geometry.Point(res[0].lng, res[0].lat),
    map.addLayer(lyr);
then nothing gets drawn. At best, this is counter-intuitive to me… the style is per point, not per layer. At worst, this creates a problem for me that I don't know how to solve. I am creating a layer that I want to reuse. If I follow the first approach above, the first time around everything works well. But, on subsequent iterations the points get drawn with the previously set style (rotation and height).
Suggestions?
Puneet Kishor
