[OpenLayers-Users] how to transform meters to degrees for radius paramater of st_dwithin function
Jaishankar Madamshetty Jaishankar.Madamshetty at infotech-enterprises.com
Mon Oct 10 12:50:00 EDT 2011
Hi All,
I have a database in Postgres with spatial ref system 4326 (SRID: 4326) and the units are 'Degrees'. I am trying to to use 'st_dwithin' function to retrieve polygons in a given range (radius) from Open Layers. I am able to send lat and lon values but not sure how to send the radius parameter which should be in spatial ref system units (i.e., degrees). I want to display drop down to user to select radius value in 'Meters'  from open layers, transform this value to spatial ref system units i.e., degrees before sending it to query. Please let me know the procedure to do this. or suggest me if any alternate process to accomplish this task.
Thanks & Regards,
Jaishankar
DISCLAIMER:
This email may contain confidential information and is intended only for the use of the specific individual(s) to which it is addressed. If you are not the intended recipient of this email, you are hereby notified that any unauthorized use, dissemination or copying of this email or the information contained in it or attached to it is strictly prohibited. If you received this message in error, please immediately notify the sender at Infotech or Mail.Admin at infotech-enterprises.com and delete the original message.
