[OpenLayers-Users] OpenLayers.Layer.Text and Vector layer above.
How to pass events to open Text layer popups?
lissabon at online.de
Wed Oct 26 08:20:13 EDT 2011
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111026/3e8e7f47/attachment.html
Hi users-list,
I've not found a solution to this by searching the web yet,:
My problem concernes OpenLayers.Layer.Text layer below an OpenLayers.Layer.Vector layer, trying to trigger the click events on the markers of the Text layer (to be able to open their popups) without deactivating the Vector overlay layer. I've read an article about Vector layer absorbing click events without a good solution IMO.
How can I solve this issue?
I've prepared an example:
There should be 2 files attached.
Alternatively you could proceed with following to achieve the same like the attached files:
Taking the Click event example from here http://openlayers.org/dev/examples/click.html
and replace the complete contents of the script tag with this (don't forget to link to the online version of the OpenLayers.js in the head-tag!):
var projMercator = new OpenLayers.Projection("EPSG:900913");
var map = new OpenLayers.Map("map");
OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, {
defaultHandlerOptions: {
'single': true,
'double': false,
'pixelTolerance': 0,
'stopSingle': false,
'stopDouble': false
initialize: function(options) {
this.handlerOptions = OpenLayers.Util.extend(
{}, this.defaultHandlerOptions
OpenLayers.Control.prototype.initialize.apply(
this, arguments
this.handler = new OpenLayers.Handler.Click(
this, {
'click': this.trigger
}, this.handlerOptions
trigger: function(e) {
var lonlat = map.getLonLatFromViewPortPx(e.xy);
alert("You clicked near " + lonlat.lat + " N, " +
+ lonlat.lon + " E");
function init(){
map.addControl(new OpenLayers.Control.LayerSwitcher());
// click handler
var click = new OpenLayers.Control.Click();
map.addControl(click);
click.activate();
// 1st layer
map.addLayer(new OpenLayers.Layer.OSM());
// 2nd layer
var pois = new OpenLayers.Layer.Text( "My Points",
projection: map.displayProjection
map.addLayer(pois);
// 3rd layer (vector layer)
var layerGeometry = new OpenLayers.Layer.Vector(
"Gebiete",
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: "geom.json",
format: new OpenLayers.Format.GeoJSON()
projection: projMercator
map.addLayer(layerGeometry);
var lonLat = new OpenLayers.LonLat( 9.5788, 48.9773 )
.transform(
new OpenLayers.Projection("EPSG:4326"), // transform from WGS 1984
map.getProjectionObject() // to Spherical Mercator Projection
var zoom=11;
map.setCenter (lonLat, zoom);
Thanks
João
