[OpenLayers-Users] Re: OpenLayers.Control.SelectFeature with
hover=true on non top vector layer.
ggarcia
ggarcia at ihman.com
Tue Sep 6 08:52:13 EDT 2011
I understand you are doing something like this:
[CODE]
// Highlight
var highlightFeature = new OpenLayers.Control.SelectFeature(
[map_vectors1, map_vectors2],
hover: true,
highlightOnly: true,
eventListeners: {
featurehighlighted: map_featureHighlight,
featureunhighlighted: map_featureUnhighlight
[/CODE]
If you want to highlight the feature that is in the bottom and your top
vector layers are covering it (some parts) you need to force the highlight:
[CODE]
map_selectFeature.highlight(featureIsBottom)
[/CODE]
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OpenLayers-Control-SelectFeature-with-hover-true-on-non-top-vector-layer-tp6745723p6763757.html
