[OpenLayers-Users] OpenLayers and GeoWebCache on GeoServer
gbrun
gbrun at myopera.com
Tue Sep 27 05:39:21 EDT 2011
Maybe a tip: in your map, you need to specify the maxExtent property with
the bounds you defined in the projection you used for your GeoWebCache
layers. Afterwards, you can specify the restrictedExtent of your map with
the extent you want to see at the screen. This way, your map has the same
bounds as your GeoWebCache layers: thus, there are no misalignment for
your tiles (they have the same origin) between the one requested by
OpenLayers and the others sent by GeoWebCache.
This tip depends on the way you have configured your GeoWebCache. In my
case, it works with WMS layers (not TMS) and a global projection defined
in GeoWebCache and assigned to each layer.
Geoffrey
Le Tue, 27 Sep 2011 11:13:35 +0200, Dipl. Inf. Carsten Eider
<eider at fh-bingen.de> a écrit:
> Hi list,
> I am looking for working examples where Openlayers uses
> WMTS/TMS/TileCache layers in order
> to get tiles from a geowebcache on a geoserver.
> I have unsuccessfully worked through all examples on openlayers, but
> nothing really works.
> Obviously i don't know how to define the bounded box of my layers.
> Are there any working examples where OL is explicitly connected to a
> geowebcache with maps restricted on defined bounds?
> TIA Carsten
Geoffrey BRUN
Étudiant en master SIGMA
Stagiaire au PNR du Haut-Languedoc
Hameau de Brassac
Saint-Pons de Thomières
+33 (0) 6 77 74 44 16
