[OpenLayers-Users] OpenLayers and GeoWebCache on GeoServer
Dipl. Inf. Carsten Eider eider at fh-bingen.de
Tue Sep 27 09:57:22 EDT 2011
Hi Geoffrey,
thank you for your small hints, but my maxExtent=restrictedExtend=The
Google-Earth
I would like to add some more baselayers resricted to some parts of
germany explicitly as any layer other than normal wms.
Any best-practice examples available?
Carsten
Am 27.09.2011 11:39, schrieb gbrun:
> Maybe a tip: in your map, you need to specify the maxExtent property
> with the bounds you defined in the projection you used for your
> GeoWebCache layers. Afterwards, you can specify the restrictedExtent
> of your map with the extent you want to see at the screen. This way,
> your map has the same bounds as your GeoWebCache layers: thus, there
> are no misalignment for your tiles (they have the same origin) between
> the one requested by OpenLayers and the others sent by GeoWebCache.
> This tip depends on the way you have configured your GeoWebCache. In
> my case, it works with WMS layers (not TMS) and a global projection
> defined in GeoWebCache and assigned to each layer.
> Geoffrey
> Le Tue, 27 Sep 2011 11:13:35 +0200, Dipl. Inf. Carsten Eider
> <eider at fh-bingen.de> a écrit:
>> Hi list,
>> I am looking for working examples where Openlayers uses
>> WMTS/TMS/TileCache layers in order
>> to get tiles from a geowebcache on a geoserver.
>> I have unsuccessfully worked through all examples on openlayers, but
>> nothing really works.
>> Obviously i don't know how to define the bounded box of my layers.
>> Are there any working examples where OL is explicitly connected to a
>> geowebcache with maps restricted on defined bounds?
>>  TIA Carsten
Mit freundlichen Grüßen / Yours faithfully
Carsten Eider
Dipl. Inf. (FH)
Kompetenzzentrum für Innovative Informationssysteme
c/o Fachhochschule Bingen / University of applied sciences Bingen
Berlinstraße 109
55411 Bingen
Tel: +49 (0) 6721 / 409-179
Fax: +49 (0) 6721 / 994-251
email: eider at fh-bingen.de
Internet: iis.fh-bingen.de
