[OpenLayers-Users] WMSGetFeatureInfo Proxy
Christian Ledermann
christian.ledermann at gmail.com
Thu Dec 6 03:32:19 PST 2012
hello
If i define:
OpenLayers.ProxyHost = 'http://myserver/proxy/@@openlayers_proxy_view?url=';
var map = cgmap.config['default-cgmap'].map;
var wmss = map.getLayersByClass('OpenLayers.Layer.WMS');
info = new OpenLayers.Control.WMSGetFeatureInfo({
url: 'http://remoteserver/wms',
title: 'Identify features by clicking',
queryVisible: true,
eventListeners: {
getfeatureinfo: function(event) {
map.addPopup(new OpenLayers.Popup.FramedCloud(
"chicken",
map.getLonLatFromPixel(event.xy),
null,
event.text,
null,
true
with the http://remoteserver/wms is the same address as the source of the layer.
It works as expected.
i want to get the WMSGetFeatureInfo to retrieve the information from
another URL e.g:
/*<![CDATA[*/
$(window).bind("load", function() {
url: 'http://myserver/wmsserver/proxy?url=',
//layers: [wmss],
queryVisible: true,
eventListeners: {
"chicken",
null,
event.text,
null,
true
map.addControl(info);
info.activate();
is it possible to point the WMSGetFeatureInfo url (local) to another
url than the Layer.WMS url (remote) ?
Best Regards,
Christian Ledermann
Nairobi - Kenya
Mobile : +254 702978914
If you save the living environment, the biodiversity that we have left,
you will also automatically save the physical environment, too. But If
you only save the physical environment, you will ultimately lose both.
1) Don’t drive species to extinction
2) Don’t destroy a habitat that species rely on.
3) Don’t change the climate in ways that will result in the above.
