[OpenLayers-Users] WMS requests executed twice
Jan Hartmann
j.l.h.hartmann at uva.nl
Wed Feb 8 09:29:05 EST 2012
No, I was too fast: the problem still shows up sometimes, even with the
development version of OpenLayers. It looks like OpenLayers does a
second request when the webserver takes a long time to return a
single-tiled map. For example, I see a single request when requesting a
WMS service on the same server within a private network, and two
requests when the request comes from the outside and has to pass several
proxies to get to the webserver. Also, low-resolution images are served
once, high-resolution ones sometimes twice. It is a bit unpredictable,
but could that be he problem?
Jan
On 02/06/2012 06:19 PM, Andreas Hocevar wrote:
> Hi,
> this was a big change
> (https://github.com/openlayers/openlayers/commit/23c909220159134d270064bc4c89440c59c22d20)
> which fixed a lot of things. In your case in particular, we now don't
> create a new IMG element for the backbuffer, but keep the existing
> image, and instead we create a new IMG element for the next tile (i.e.
> the new extent for single tile layers). For tiles without a cache
> header (which might get stripped by a proxy), the old behavior meant
> that the tile is re-requested for the backbuffer.
> Andreas.
> On Mon, Feb 6, 2012 at 12:21 PM, Jan Hartmann<j.l.h.hartmann at uva.nl> wrote:
>> Yes, it *was* that issue: with the development version of OpenLayers layers
>> are always retrieved just once. Thanks Andreas. Just curiosity, can you give
>> me a pointer to what the problem was?
>> BTW, I don't get all messages from the OpenLayers Users list in my mailbox.
>> Had to look up your answers in the archive.
>> Jan
>> Andreas Hocevar wrote on Mon, 6 Feb 2012 04:01:51 EST 2012
>> Hi, just to clarify, the issue you are seeing (if it's the issue I think it
>> is) was fixed *after* 2.11. Andreas.
>> Hi Andreas,
>> No, I use OpenLayers 2.11. I see now that it has something to do with my
>> proxy. All maps are on webservers in an internal network and are accessed
>> via one proxy.When I run the page on the local server, maps are retrieved
>> only once. When I access that same server from the outside, via the proxy,
>> all maps are retrieved twice.
>> Although this is probably not an OpenLayers problem, I would be gratefule
>> for suggestions. It took me quite some time to get the proxy configuration
>> running. It works now, but takes twice as much time as needed.
>> Jan
>> Andreas Hocevar wrote on Mon, 23 Jan 2012 04:58:20 -0800: This might be due
>> to a bug that has been fixed quite some time ago already. Which version of
>> OpenLayers are you using? Andreas.
>> On 01/21/2012 09:27 PM, Jan Hartmann wrote:
>> Hi all,
>> I made a very simple OpenLayers test site, displaying a simple local
>> MapServer map as an untiled WMS service. Works fine, but when I look in the
>> server log, each OpenLayer GetMap request results in *two* identical
>> requests to the server. Can anyone confirm this, and why does it happen?
>> Jan Hartmann
>> Amsterdam
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120208/704d1599/attachment.html
