[OpenLayers-Users] Re: SelectFeature when using IE<9 or IE9 Compatibility View
Peter Peterse peter at peterse-uithuizen.com
Tue Feb 14 15:04:00 EST 2012
Hello Andreas,
Thanks for your reply. The style rotation works fine. But when I use the
dragFeature it don't work in some IE versions. I'm working on a rather
big OL project and there I had trouble with the dragFeature in IE7 and
IE8. IE9 works there correct. I found the result in disableing the
snapping-tool. When I try to write a bug request
<http://osm.peterse-uithuizen.com/~peter/dragTrouble/index.html> it
worked in IE8 but not in IE9. I've changed this example with only the
remove of the rotate style
<http://osm.peterse-uithuizen.com/~peter/dragTrouble/index2.html> and
after this the dragFeature worked also in IE9.
I hope someone can find the error I make. It is probably a stupid one
Regards,
Peter
Op 14-2-2012 9:21, Andreas Hocevar schreef:
> Hi Peter,
> the example to test this is
> http://openlayers.org/dev/examples/styles-rotation.html (hover over
> features to see the SelectFeature control in action). For what it's
> worth, it works fine in both IE8 and IE9 for me. The thing with IE9
> and vector rendering is that you really shouldn't be using
> compatibility mode. If you do so, neither VML nor SVG work properly.
> Andreas.
