[OpenLayers-Users] Re: Google + WMS
Ricardo Bayley
ricardo.bayley at gmail.com
Mon Feb 20 18:46:06 EST 2012
No, I am not using the Ext framework nor Sencha. Just plain OpenLayers 2.11
Ricardo
2012/2/17 jrom <jerome.gasperi at gmail.com>
> Hi Ricardo,
> I had the same problem long time ago when i was using Ext framework.
> Are you using it ?
> Regards
> 2012/2/17 Ricardo Bayley <ricardo.bayley at gmail.com>:
> > Nobody experienced something like this ?
> > 2012/2/6 Ricardo Bayley <ricardo.bayley at gmail.com>
> >> Hi folks,
> >> I am experiencing a serious issue. I have two base layers, a WMS layer
> of
> >> my own (geoserver) and a google base layer.
> >> After switching between them, sometimes, google layer is reduce for
> about
> >> 1/8 th of the map div size and is position at the upper left corner.
> >> I can switch back and forth between them, the WMS will fit perfect, but
> >> google layer will stay 1/8th on the upper left corner.
> >> To see it properly, I have to reload the page. Curious thing is that if
> I
> >> never switch to my WMS base layer, then google wont be reduce.
> >> I am using gmap v2.
> >> Has anyone experience something like this ? Could my setup be wrong or
> did
> >> I bumped into a bug ?
> >> this is my gmap config:
> >> gmap : new OpenLayers.Layer.Google(
> >> "Google Streets", // the default
> >> type: G_NORMAL_MAP , // v2
> >> // type: google.maps.MapTypeId.ROADMAP, //v3
> >> sphericalMercator: true, minZoomLevel: 4, maxZoomLevel: 16
> >> best regards,
> >> Ricardo
> > Users mailing list
> > Users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
> http://mapshup.info
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120220/22fa76f8/attachment.html
