[OpenLayers-Users] OpenLayers polygon fill on IE has black
shading after setting opacity
Andreas Hocevar
ahocevar at opengeo.org
Thu Jan 12 05:12:42 EST 2012
this is a bug in IE, and there doesn't seem to be a known workaround:
http://social.msdn.microsoft.com/Forums/en/iewebdevelopment/thread/c2cc8d05-cffd-4454-900f-785e5ce78919
Andreas.
On Wed, Jan 11, 2012 at 8:42 PM, Vadim Bokin <vbokin at gmail.com> wrote:
> I apologize up front, but this is a cross-post from gis.stackexchange. I
> asked the question there, w/o much response, so I think this may be an OL
> bug rather than a "how do I use it" question. I'm going to duplicate the
> post here and also available at
> http://gis.stackexchange.com/questions/18677/openlayers-polygon-fill-on-ie-has-black-shading
> I have an odd problem on with OpenLayers on IE6, IE7 and IE8. A newly drawn
> polygon has odd black shading. In fact, even the line (stroke) has the same
> black outline.
> Works great in Firefox, Chrome, Safari and even IE9.
> I've tried everything from creating my own stylemap and symbolizers, to
> removing all styles and using default layer, and it still has a problem.
> And to add to the puzzle, if you draw a second feature and intersect with
> the first, the intersected area has *perfect* colorization/rendering.
> I've tried changing the basic style to have a different color (say blue) but
> then the color is again the base blue plus the black shading/fill attached
> to it.
> http://osgeo-org.1803224.n2.nabble.com/file/n7177631/Uk1KH.png
> Have run the basic drawing example,
> http://www.openlayers.org/dev/examples/draw-feature.html and it works just
> fine on all browsers.
> http://osgeo-org.1803224.n2.nabble.com/file/n7177631/w5HLA.png
> Edit 1/10 5p PST
> I was finally able to create a stripped-down sample that reproduce the
> error.
> I wrote a page that accepts a URL param to enable the bug, and it'll be
> broken in IE8,7,and 6. All you have to do is draw a polygon, and you'll see
> that it comes out black
> http://dl.dropbox.com/u/47684/nc4/debug/RenderTest.html?break=1
> And here's the source:
> As you can see, just setting the layer OPACITY will break it. And this
> actually breaks on IE6 and 7. It works on 8, but I have compatibility mode
> set to 7, so yes that makes it break on 8.
> Why setting opacity is breaking? I've traced the code down to `Util.js` and
> the `modifyDOMElement` function, and it *looks* to be ok. But... ?
> Thank you.
> -Vadim
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/OpenLayers-polygon-fill-on-IE-has-black-shading-after-setting-opacity-tp7177631p7177631.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
