[OpenLayers-Users] Re: SVG Overlay
fatzopilot
fatzopilot at gmx.net
Sat Jan 14 10:22:27 EST 2012
Hey,
Thanks for the info, it seems to work quite well (a minor problem are
different output sizes in each browser if size is not expicitly specified)
except for IE9 where the icon just does not show up.
I modified the GwtOpenLayersShowcase Labeled Features showcase for testing
(it uses a vector layer).
Since IE9 normally supports at least the most important subset of SVG
(tested it by rendering a simple SVG file in IE9), I wonder what might be
the issue with it. Is it maybe because openlayers assumes SVG is not
supported in IE and just takes a detour via VML for rendering (which seems
to fail in case of single SVG files)?
Regards,
fatzopilot
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SVG-Overlay-tp7050997p7187723.html
