[OpenLayers-Users] with no OpenLayers.Util.onImageLoadError,
TileCache wrapDateLine has pink tiles
Charlton Galvarino
charlton at 2creek.com
Mon Jan 16 09:49:38 EST 2012
Thanks, Andreas. I appreciate the pointers.
>-----Original Message-----
>From: andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] On
>Behalf Of Andreas Hocevar
>Sent: Saturday, January 14, 2012 4:05 PM
>To: Charlton Galvarino
>Cc: openlayers-users at lists.osgeo.org
>Subject: Re: [OpenLayers-Users] with no OpenLayers.Util.onImageLoadError,
>Hi,
>to style the way tiles with unavailable images look, modify the
>.olImageLoadError css class, e.g. like this:
>.olImageLoadError { display: none; }
>Now for the correct usage of wrapDateLine: true - it only works correctly if set
>on the base layer, and if the base layer's maxExtent's left and right bounds
>equal the world extent's. With other
>words: don't use it for tile caches that only cover a subset of the world in
>longitudinal direction.
>Andreas.
>On Sat, Jan 14, 2012 at 6:01 AM, Charlton Galvarino <charlton at 2creek.com>
>wrote:
>> Hi, all. I just grabbed the latest and greatest OL from github and
>> see that OpenLayers.Util.onImageLoadError is no more. One thing I
>> noticed off the bat is that my TileCache layers (wrapDateLine : true)
>> show pink tiles outside of the usual -180,-90,180,90 bounds. That
>> used to be handled by the onImageLoadError, but I'm not sure where to
>look now.
>> I can reproduce this behavior in the tilecache.html example by
>> commenting out the map's resolutions (so you can zoom way out) and
>> adding wrapDateLine
>> : true to the layer's config. Not having the wrapDateLine works as
>> advertised . . . no pink tiles. But having it seems to break something.
>> Am I missing something obvious?
>> TIA.
>> Charlton Galvarino
>> 1 (803) 233-6205 : voice
>> 1 (803) 223-9579 : fax
>> P.O. Box 50960
>> Columbia, SC 29250
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>Andreas Hocevar
>OpenGeo - http://opengeo.org/
>Expert service straight from the developers.
