[OpenLayers-Users] area enclosed by linestring
Jim White
jbw2003 at earthlink.net
Sun Jan 15 16:23:03 EST 2012
I tried that first. It was way off. I think by a factor of cos(lat)**2.
On 01/15/2012 03:24 PM, Toby Reinicke wrote:
> Do you have the same issue if you just use ring.getArea() function?
> On 15 Jan 2012, at 18:31, Jim White<jbw2003 at earthlink.net> wrote:
>> Hi,
>> I use this to calculate the number of acres enclosed by a linestring:
>> ring = new OpenLayers.Geometry.LinearRing(geometry.getVertices());
>> area = ring.getGeodesicArea(new OpenLayers.Projection("EPSG:900913"));
>> area = Math.floor(Math.abs(area*0.000247105381));
>> The calculated area consistently produces results that are 2-3% too small. Is this an error in my code or is my data the problem?
>> Thanks,
>> Jim White
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
