[OpenLayers-Users] area enclosed by linestring
Tobias Reinicke
ramotswa at gmail.com
Sun Jan 15 16:42:16 EST 2012
Fair enough. I presume you aren't drawing the linestring by hand yes?
and that there are no obvious rounding errors?
Toby
On 15 January 2012 21:23, Jim White <jbw2003 at earthlink.net> wrote:
> I tried that first. It was way off. I think by a factor of cos(lat)**2.
> On 01/15/2012 03:24 PM, Toby Reinicke wrote:
>> Do you have the same issue if you just use ring.getArea() function?
>> On 15 Jan 2012, at 18:31, Jim White<jbw2003 at earthlink.net> wrote:
>>> Hi,
>>> I use this to calculate the number of acres enclosed by a linestring:
>>> ring = new OpenLayers.Geometry.LinearRing(geometry.getVertices());
>>> area = ring.getGeodesicArea(new OpenLayers.Projection("EPSG:900913"));
>>> area = Math.floor(Math.abs(area*0.000247105381));
>>> The calculated area consistently produces results that are 2-3% too
>>> small. Is this an error in my code or is my data the problem?
>>> Thanks,
>>> Jim White
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
