[OpenLayers-Users] Use of MBTIles with openlayers
Robert Buckley robertdbuckley at yahoo.com
Wed Jan 25 11:58:45 EST 2012
Thanks for the reply,
So TileStache can serve and render the MBTiles to use with openlayers? Would you know if there are possibilities for exporting mapcontent from the openlayers mappanel?
This is one of the reasons i´m looking in this directory as I can´t do pdf exports with geowebcache served from geoserver.
Thanks,
Rob
 Von: Greg Allensworth <gregor at greeninfo.org>
An: Robert Buckley <robertdbuckley at yahoo.com>
Cc: "users at openlayers.org" <users at openlayers.org>
Gesendet: 17:51 Mittwoch, 25.Januar 2012
Betreff: Re: [OpenLayers-Users] Use of MBTIles with openlayers
On 1/25/2012 4:18 AM, Robert Buckley wrote:
> Has anyone successfully used MBTiles to server
> basemaps in Openlayers? Do any live example exist if yes?
You need server-side software to open the MBTiles file and fetch the tiles. TileStache and TileStream are two popular servers for doing this.
TileStache is Python and I found it fairly easy to set up. It runs under Apache as CGI, mod_python, or WSGI. If you have an existing web server and web content, this is probably the easiest way to go.
TileStream is written in Node JS and takes a bit more setup. It does not run under Apache, but is its own server with its own service port and it has some behaviors regarding the hostname of incoming requests -- running it on port 80 with your other web content is not simple.
-- Greg Allensworth, Web GIS Developer
BS  A+  Network+  Security+  Linux+  Server+
GreenInfo Network - Information and Mapping in the Public Interest
564 Market Street, Suite 510  San Francisco CA 94104
PH: 415-979-0343 x302  FX: 415-979-0371    email: gregor at greeninfo.org
Web: www.GreenInfo.org     www.MapsPortal.org
Subscribe to MapLines, our e-newsletter, at www.GreenInfo.org
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120125/71e02504/attachment-0001.html
