[OpenLayers-Users] PopUps: Markers and Lines
adidas
xkadidas at gmail.com
Wed Jul 4 02:08:39 PDT 2012
Hello! Markers are drawn on a map using poi, a line draw as LineString
(pop-up is done as in this example:
http://openlayers.org/dev/examples/select-feature-openpopup.html ).
Problem: if you select the checkbox "select polygon on click", then if
you click on a marker, a popup will not display, if you click on the
line - a popup window is displayed.
If you select the checkbox "navigate", then if you click on the marker -
will display a pop-up window, and if you click on the line - will not
display a pop-up window. How to solve this problem? It is necessary that
if you click on a marker or line display pop-up window.
Map here: http://softez.pp.ua/fiberms/fiberms/map.php
Help, please!
Thanks!
