[OpenLayers-Users] Fwd: my vector data don't show up - wfs
Pedro Costa pedrocostaarma at sapo.pt
Wed Jul 4 03:33:24 PDT 2012
Thanks Gery...
I think that now i'm using ol firebug because i got alerts:
proxyNeeded Object { url="http://localhost:8080/geoserver/testes/wfs"}
This means i nedd proxy despite i'm using only local data?
Thanks
Em 04-07-2012 11:16, Gery . escreveu:
> Hola Pedro,
> I don't know if this helps, but you're using firebug as add-on of
> firefox or the one it comes with OpenLayers? I think you're using the
> first one. I've had better results (generally spoken) with the second
> one, just add the path of the javascript to your html <link>, I don't
> remember well the path but if I'm not wrong is
> /openlayers/lib/openlayers/Firebug.js, you can google it also. That js
> script is really useful, it tells in detail where the error is (ie.
> which js script and which line), at least in my case. Also, even
> though I don't work with geoserver or bing, I think you have to
> specify the projection in bing, but not sure. Sometimes I found that
> projection stuff is the one that *ucks everything.
> Hope this helps,
> Gery
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas
> si NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt- bewahren Sie es auf dem Bildschirm. Drucken
> Sie NICHT, wenn es NICHT notwendig ist.
> Date: Wed, 4 Jul 2012 11:06:36 +0100
> From: pedrocostaarma at sapo.pt
> To: ramotswa at gmail.com; openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
> Also no erros on console...
> Anybody have an ideia?
> all the code here:
> http://pastebin.com/mRnDC3UG
> Em 04-07-2012 10:58, Toby Reinicke escreveu:
>     Umm, yes, theoretically, although I'm slightly confused why there
>     is only one tab and hasn't got a response one. Your syntax looks
>     fine, although others might be able to confirm that. As for proxy,
>     as you say you should be fine, and if it wasn't you'd get some
>     cross domain errors in your console..
>     Sorry I can't help more.
>     Toby
>     On 4 Jul 2012, at 10:27, Pedro Costa <pedrocostaarma at sapo.pt
>     <mailto:pedrocostaarma at sapo.pt>> wrote:
>         Hi Tobias,
>         This(image attached)?
>             Em 04-07-2012 10:21, Tobias Reinicke escreveu:
>                 If you expand that "options.wfs" in the firebug
>                 console, what does the "response" tab have in it?
>                 On 4 July 2012 10:09, Pedro Costa
>                     I forgot image....
>                     -------- Mensagem Original --------
>                     Assunto: 	my vector data don't show up - wfs
>                     Data: 	Wed, 04 Jul 2012 09:56:54 +0100
>                     De: 	Pedro Costa <pedrocostaarma at sapo.pt>
>                     Para: 	openlayers-users at lists.osgeo.org
>                     <mailto:openlayers-users at lists.osgeo.org>
>                     Hi,
>                     I'm trying to add vector data to my map from geoserver but data don't
>                     show up.
>                     I tried like that:
>                     var wfs = new OpenLayers.Layer.Vector("Equipamentos_WFS", {
>                                  strategies: [new OpenLayers.Strategy.BBOX()],
>                                  protocol: new OpenLayers.Protocol.WFS({
>                                  url:"http://localhost:8080/geoserver/testes/wfs"  <http://localhost:8080/geoserver/testes/wfs>,
>                                  featurePrefix:"testes",
>                                  featureType: "testes:equipamentos",
>                                  featureNS: "namespacetestes.pt  <http://namespacetestes.pt>",
>                                  srsName: "EPSG:900913",
>                                  geometryName: "the_geom",
>                                  version: "1.0.0"
>                     map.addLayer(wfs);
>                     I'm using only data from localhost (my computer) so i don't need proxy
>                     right?
>                     Using firebug I can see that the request is made, but returns nothing
>                     (image attached).
>                     Can anybody help me?
>                     Thanks
>                     Users mailing list
>                     Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
>                     http://lists.osgeo.org/mailman/listinfo/openlayers-users
>         <request.png>
> _______________________________________________ Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120704/89e93ae6/attachment.html>
