[OpenLayers-Users] Fwd: my vector data don't show up - wfs
Gery .
gamejihou at hotmail.com
Wed Jul 4 03:37:18 PDT 2012
Hi Pedro,
Glad to hear that it was useful to you and it worked. Well, I think you better do what this console says, it is a very clever one =)
If it says that it needs a proxy, it is very likely it needs one, just add the one you use, localhost:8080 or something like that, you can start playing with that and the FB console will tell you what to do after each step. Trust in this console, it's our friend =)
Cheers,
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
Date: Wed, 4 Jul 2012 11:33:24 +0100
To: gamejihou at hotmail.com; openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
Thanks Gery...
I think that now i'm using ol firebug because i got alerts:
proxyNeeded
Object { url="http://localhost:8080/geoserver/testes/wfs"}
This means i nedd proxy despite i'm using only local data?
Thanks
Em 04-07-2012 11:16, Gery . escreveu:
Hola Pedro,
I don't know if this helps, but you're using firebug as add-on
of firefox or the one it comes with OpenLayers? I think you're
using the first one. I've had better results (generally
spoken) with the second one, just add the path of the
javascript to your html <link>, I don't remember well
the path but if I'm not wrong is
/openlayers/lib/openlayers/Firebug.js, you can google it also.
That js script is really useful, it tells in detail where the
error is (ie. which js script and which line), at least in my
case. Also, even though I don't work with geoserver or bing, I
think you have to specify the projection in bing, but not
sure. Sometimes I found that projection stuff is the one that
*ucks everything.
Hope this helps,
Gery
Date: Wed, 4 Jul 2012 11:06:36 +0100
To: ramotswa at gmail.com; openlayers-users at lists.osgeo.org
up - wfs
Also no erros on console...
Anybody have an ideia?
all the code here:
http://pastebin.com/mRnDC3UG
Em 04-07-2012 10:58, Toby Reinicke escreveu:
Umm, yes, theoretically, although I'm slightly confused
why there is only one tab and hasn't got a response one.
Your syntax looks fine, although others might be able to
confirm that. As for proxy, as you say you should be fine,
and if it wasn't you'd get some cross domain errors in
your console..
Sorry I can't help more.
Toby
On 4 Jul 2012, at 10:27, Pedro Costa <pedrocostaarma at sapo.pt>
wrote:
Hi Tobias,
This(image attached)?
Em 04-07-2012 10:21, Tobias Reinicke escreveu:
If
you expand that "options.wfs" in the firebug
console, what does the "response" tab have in it?
On 4 July 2012 10:09,
wrote:
I forgot image....
-------- Mensagem Original --------
Assunto:
wfs
Data:
Wed, 04 Jul 2012 09:56:54
+0100
De:
Para:
I'm trying to add vector data to my map from geoserver but data don't
show up.
I tried like that:
var wfs = new OpenLayers.Layer.Vector("Equipamentos_WFS", {
strategies: [new OpenLayers.Strategy.BBOX()],
protocol: new OpenLayers.Protocol.WFS({
url: "http://localhost:8080/geoserver/testes/wfs",
featurePrefix:"testes",
featureType: "testes:equipamentos",
featureNS: "namespacetestes.pt",
srsName: "EPSG:900913",
geometryName: "the_geom",
version: "1.0.0"
map.addLayer(wfs);
I'm using only data from localhost (my computer) so i don't need proxy
right?
Using firebug I can see that the request is made, but returns nothing
(image attached).
Can anybody help me?
Thanks
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
<request.png>
Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120704/ae276065/attachment-0001.html>
