[OpenLayers-Users] Fwd: my vector data don't show up - wfs
Pedro Costa pedrocostaarma at sapo.pt
Wed Jul 4 07:04:39 PDT 2012
Thank you Gery.
Now my proxy is working but i got this error in firebug:
'Access to restricted URI denied'
My code:
http://pastebin.com/AGAFGSfn
Em 04-07-2012 11:37, Gery . escreveu:
> Hi Pedro,
> Glad to hear that it was useful to you and it worked. Well, I think
> you better do what this console says, it is a very clever one =)
> If it says that it needs a proxy, it is very likely it needs one, just
> add the one you use, localhost:8080 or something like that, you can
> start playing with that and the FB console will tell you what to do
> after each step. Trust in this console, it's our friend =)
> Cheers,
> Gery
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas
> si NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt- bewahren Sie es auf dem Bildschirm. Drucken
> Sie NICHT, wenn es NICHT notwendig ist.
> Date: Wed, 4 Jul 2012 11:33:24 +0100
> From: pedrocostaarma at sapo.pt
> To: gamejihou at hotmail.com; openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
> Thanks Gery...
> I think that now i'm using ol firebug because i got alerts:
> proxyNeeded Object { url="http://localhost:8080/geoserver/testes/wfs"}
> This means i nedd proxy despite i'm using only local data?
> Thanks
> Em 04-07-2012 11:16, Gery . escreveu:
>     Hola Pedro,
>     I don't know if this helps, but you're using firebug as add-on of
>     firefox or the one it comes with OpenLayers? I think you're using
>     the first one. I've had better results (generally spoken) with the
>     second one, just add the path of the javascript to your html
>     <link>, I don't remember well the path but if I'm not wrong is
>     /openlayers/lib/openlayers/Firebug.js, you can google it also.
>     That js script is really useful, it tells in detail where the
>     error is (ie. which js script and which line), at least in my
>     case. Also, even though I don't work with geoserver or bing, I
>     think you have to specify the projection in bing, but not sure.
>     Sometimes I found that projection stuff is the one that *ucks
>     everything.
>     Hope this helps,
>     Gery
>     imprimas si NO es necesario.
>     necessary.
>     Drucken Sie NICHT, wenn es NICHT notwendig ist.
>     Date: Wed, 4 Jul 2012 11:06:36 +0100
>     From: pedrocostaarma at sapo.pt <mailto:pedrocostaarma at sapo.pt>
>     To: ramotswa at gmail.com <mailto:ramotswa at gmail.com>;
>     <mailto:openlayers-users at lists.osgeo.org>
>     - wfs
>     Also no erros on console...
>     Anybody have an ideia?
>     all the code here:
>     http://pastebin.com/mRnDC3UG
>     Em 04-07-2012 10:58, Toby Reinicke escreveu:
>         Umm, yes, theoretically, although I'm slightly confused why
>         there is only one tab and hasn't got a response one. Your
>         syntax looks fine, although others might be able to confirm
>         that. As for proxy, as you say you should be fine, and if it
>         wasn't you'd get some cross domain errors in your console..
>         Sorry I can't help more.
>         Toby
>         On 4 Jul 2012, at 10:27, Pedro Costa <pedrocostaarma at sapo.pt
>         <mailto:pedrocostaarma at sapo.pt>> wrote:
>             Hi Tobias,
>             This(image attached)?
>                 Em 04-07-2012 10:21, Tobias Reinicke escreveu:
>                     If you expand that "options.wfs" in the firebug
>                     console, what does the "response" tab have in it?
>                     On 4 July 2012 10:09, Pedro Costa
>                         I forgot image....
>                         -------- Mensagem Original --------
>                         Assunto: 	my vector data don't show up - wfs
>                         Data: 	Wed, 04 Jul 2012 09:56:54 +0100
>                         De: 	Pedro Costa <pedrocostaarma at sapo.pt>
>                         Para: 	openlayers-users at lists.osgeo.org
>                         Hi,
>                         I'm trying to add vector data to my map from geoserver but data don't
>                         show up.
>                         I tried like that:
>                         var wfs = new OpenLayers.Layer.Vector("Equipamentos_WFS", {
>                                      strategies: [new OpenLayers.Strategy.BBOX()],
>                                      protocol: new OpenLayers.Protocol.WFS({
>                                      url:"http://localhost:8080/geoserver/testes/wfs"  <http://localhost:8080/geoserver/testes/wfs>,
>                                      featurePrefix:"testes",
>                                      featureType: "testes:equipamentos",
>                                      featureNS: "namespacetestes.pt  <http://namespacetestes.pt>",
>                                      srsName: "EPSG:900913",
>                                      geometryName: "the_geom",
>                                      version: "1.0.0"
>                         map.addLayer(wfs);
>                         I'm using only data from localhost (my computer) so i don't need proxy
>                         right?
>                         Using firebug I can see that the request is made, but returns nothing
>                         (image attached).
>                         Can anybody help me?
>                         Thanks
>                         Users mailing list
>                         Users at lists.osgeo.org
>                         <mailto:Users at lists.osgeo.org>
>                         http://lists.osgeo.org/mailman/listinfo/openlayers-users
>             <request.png>
>     _______________________________________________ Users mailing list
>     Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120704/c4934234/attachment-0001.html>
