[OpenLayers-Users] Fwd: my vector data don't show up - wfs
Gery .
gamejihou at hotmail.com
Wed Jul 4 09:52:22 PDT 2012
Hi Pedro,
I was reading about this error in google and it seems that this is one of the solutions, you have to use this:
var url = 'proxy_php.php?fn=' + encodeURIComponent(src);
it seems that the problem is ajax (as far I understand), but it can be firefox, try first in IE or safari to see what happens. Also this page is suggested about the php code above:
http://developer.yahoo.com/javascript/howto-proxy.html
This page is in spanish, it may help you: http://www.forosdelweb.com/f127/ayuda-access-restricted-uri-denied-599455/
Cheers,
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
Date: Wed, 4 Jul 2012 15:04:39 +0100
To: gamejihou at hotmail.com; openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
Thank you Gery.
Now my proxy is working but i got this error in firebug:
'Access to
restricted URI denied'
My code:
http://pastebin.com/AGAFGSfn
Em 04-07-2012 11:37, Gery . escreveu:
Hi Pedro,
Glad to hear that it was useful to you and it
worked. Well, I think you better do what this console says, it
is a very clever one =)
If it says that it needs a proxy, it is very likely it needs
one, just add the one you use, localhost:8080 or something
like that, you can start playing with that and the FB console
will tell you what to do after each step. Trust in this
console, it's our friend =)
Cheers,
Gery
Date: Wed, 4 Jul 2012 11:33:24 +0100
up - wfs
Thanks Gery...
I think that now i'm using ol firebug because i got alerts:
proxyNeeded Object {
url="http://localhost:8080/geoserver/testes/wfs"}
This means i nedd proxy despite i'm using only local
data?
Thanks
Em 04-07-2012 11:16, Gery . escreveu:
Hola Pedro,
I don't know if this helps, but you're using firebug as
add-on of firefox or the one it comes with OpenLayers? I
think you're using the first one. I've had better
results (generally spoken) with the second one, just add
the path of the javascript to your html <link>, I
don't remember well the path but if I'm not wrong is
/openlayers/lib/openlayers/Firebug.js, you can google it
also. That js script is really useful, it tells in
detail where the error is (ie. which js script and which
line), at least in my case. Also, even though I don't
work with geoserver or bing, I think you have to specify
the projection in bing, but not sure. Sometimes I found
that projection stuff is the one that *ucks everything.
Hope this helps,
Gery
necesario.
Denken
Sie an die Umwelt -
Date: Wed, 4 Jul 2012 11:06:36
+0100
To: ramotswa at gmail.com;
don't show up - wfs
Also no erros on
console...
Anybody have an ideia?
all the code here:
http://pastebin.com/mRnDC3UG
Em 04-07-2012 10:58, Toby Reinicke escreveu:
Umm, yes, theoretically, although I'm slightly
confused why there is only one tab and hasn't got a
response one. Your syntax looks fine, although
others might be able to confirm that. As for proxy,
as you say you should be fine, and if it wasn't
you'd get some cross domain errors in your
console..
Sorry I can't help more.
Toby
On 4 Jul 2012, at 10:27, Pedro Costa <pedrocostaarma at sapo.pt>
wrote:
Hi Tobias,
This(image attached)?
Em 04-07-2012 10:21, Tobias Reinicke escreveu:
If
you expand that "options.wfs" in the firebug
console, what does the "response" tab have in
it?
On 4 July 2012
10:09, Pedro Costa <pedrocostaarma at sapo.pt>
wrote:
I forgot image....
-------- Mensagem Original
Assunto:
show up - wfs
Data:
Wed, 04 Jul 2012
09:56:54 +0100
De:
Para:
I'm trying to add vector data to my map from geoserver but data don't
show up.
I tried like that:
var wfs = new OpenLayers.Layer.Vector("Equipamentos_WFS", {
strategies: [new OpenLayers.Strategy.BBOX()],
protocol: new OpenLayers.Protocol.WFS({
url: "http://localhost:8080/geoserver/testes/wfs",
featurePrefix:"testes",
featureType: "testes:equipamentos",
featureNS: "namespacetestes.pt",
srsName: "EPSG:900913",
geometryName: "the_geom",
version: "1.0.0"
map.addLayer(wfs);
I'm using only data from localhost (my computer) so i don't need proxy
right?
Using firebug I can see that the request is made, but returns nothing
(image attached).
Can anybody help me?
Thanks
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
<request.png>
_______________________________________________ Users
mailing list Users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120704/b675f95b/attachment-0001.html>
