[OpenLayers-Users] how do I load deprecated.js from hosted API location(http://openlayers.org/api)?
Andreas Hocevar
ahocevar at opengeo.org
Thu Jul 12 00:05:16 PDT 2012
On Thu, Jul 12, 2012 at 8:44 AM, richard hanssen <semska at gmail.com> wrote:
> You should probably change your layer type from OpenLayers.Layer.GML
> to OpenLayers.Layer.Vector and use the format option to indicate what
> type of data the layer can expect. Same goes for OpenLayers.KML i
> think.
Yes, this is the right thing to do to remove dependencies for
deprecated classes from your application.
Andreas.
> On Wed, Jul 11, 2012 at 10:11 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>> Hard to tell what's wrong without seeing your code. It's likely that
>> your code uses a non-API method that has changed since 2.11. If you
>> share your code, people on this list can maybe help you.
>> The deprecated.js file should be in the src/lib/OpenLayers directory
>> of the .tar.gz.
>> Andreas.
>> On Wed, Jul 11, 2012 at 9:55 PM, Kevin Halton
>> <kevin_halton at hotmail.co.uk> wrote:
>>>> My code had loaded a KML data set using Layer.GML with a
>>>> OpenLayers.Format.KML format. What's the proper way to display a KML
>>>> layer in 2.12?
>>> I'm in exactly the same boat. I've tried using the online deprecated.js file, but as you say it's not there. I tried extracting it from the 2.12.tar.gz, but it's not there either. Finally I managed to download it from github, and it does get rid of the "OpenLayers.Layer.GML is not a constructor" error message, but it doesn't show my KML track any more either.
>>> I've tried using a local copy of 2.11's OpenLayers.js, without success. And I've gone through all the online examples looking for an example of showing a _track_ line (not just waypoints) from a KML file, again without success.
>>> Are there any instructions anywhere of how to cope with this ? It's just a few lines of layer definition which worked fine until this upgrade.
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Users mailing list
Andreas Hocevar
