[OpenLayers-Users] particular WFS as VECTOR to the MAP
islanis linares islanis at infomed.sld.cu
Sun Jul 22 04:27:34 PDT 2012
Hi all list, i want to create a vector with only 2 of all my states in a map
served in geoserver that i use
like a normal wms map in my prove system, but i dont know how i have  to do
to bring 2 of all the states in
the form of vectors i made some code but am stack, here is my incomplete
code, i need some help from you,
thanks a lot.
var vlayerMunicipios;
vlayerMunicipios = new OpenLayers.Layer.Vector("Municipios disponibles");
var municipios = new OpenLayers.Layer.WMS(
"Puntos de Biogas disponibles",
"http://localhost:8080/geoserver/une/wms",
   'layers' : 'une:uneMunicipios', transparent : true, format : 'image/gif'
   isBaseLayer : false
map.addLayers([municipios,vlayerMunicipios]);
map.zoomToMaxExtent();
function useLayerInMap(layerr, vectorr){
     if( ! (layerr instanceof OpenLayers.Layer.WMS)) {
          return;
                if( ! (vectorr instanceof OpenLayers.Layer.Vector)) {
          return;
                vectorr.removeAllFeatures();
                var url = layerr.url.split("?")[0];
                var schema = new GeoExt.data.AttributeStore({
      url : url,
      baseParams : {
         "SERVICE" : "WFS",
         "REQUEST" : "DescribeFeatureType",
         "VERSION" : "1.1.0",
         "TYPENAME" : layerr.params.LAYERS
      autoLoad : true,
      listeners : {
         "load" : function(store) {
            //featureGrid.setTitle(layer.name);
            //selectedLayer = layer;
            //configureGrid(store, url);
useLayerInMap(municipios , vlayerMunicipios);
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120722/1b098c53/attachment.html>
