[OpenLayers-Users] OL 2.12 and Image layer flicker
teknocreator teknocreator at gmail.com
Mon Jul 23 08:52:19 PDT 2012
I should clarify that I don't have the fix mentioned as #560 working yet.
What I referenced below was for OL2.11 and OL2.10, not 2.12.  So, still
looking through #560 and seeing what I need to do here.
Dave
On Mon, Jul 23, 2012 at 11:46 AM, David Miller <teknocreator at gmail.com>wrote:
> Benjamin,
> Depends on what your needs are.  In the original case, the fix pretty much
> eliminated the flicker and was easy to incorporate.  So, one can always
> test fixes by copying off original, incorporating the fixed code, and
> testing it.  I'm attempting to do that and will email back.  I must be
> missing something, though, as my first attempt ended with an error.  Again,
> let me report back with results once I have this running successfully.
> Dave
> On Fri, Jul 20, 2012 at 5:54 AM, Bennos [via OSGeo.org] <
> ml-node+s1560n4989578h53 at n6.nabble.com> wrote:
>> I saw there was a possible fix for this problem in the ticket. I wanted
>> to ask if you suggest to use this fix or to stay with OL 2.11 and the old
>> solution. I mean, is it safe to use the fix, or better to wait until it is
>> further developed?
>> Thank you
>> Benjamin
>>  If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.n6.nabble.com/OL-2-12-and-Image-layer-flicker-tp4984910p4989578.html
>>  To unsubscribe from OL 2.12 and Image layer flicker, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4984910&code=dGVrbm9jcmVhdG9yQGdtYWlsLmNvbXw0OTg0OTEwfDEyMzgzMDYzOTQ=>
>> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/OL-2-12-and-Image-layer-flicker-tp4984910p4990128.html
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120723/2b6fd191/attachment.html>
