[OpenLayers-Users] OL 2.12 and Image layer flicker
teknocreator
teknocreator at gmail.com
Mon Jul 23 08:46:53 PDT 2012
Benjamin,
Depends on what your needs are. In the original case, the fix pretty much
eliminated the flicker and was easy to incorporate. So, one can always
test fixes by copying off original, incorporating the fixed code, and
testing it. I'm attempting to do that and will email back. I must be
missing something, though, as my first attempt ended with an error. Again,
let me report back with results once I have this running successfully.
Dave
On Fri, Jul 20, 2012 at 5:54 AM, Bennos [via OSGeo.org] <
ml-node+s1560n4989578h53 at n6.nabble.com> wrote:
> I saw there was a possible fix for this problem in the ticket. I wanted to
> ask if you suggest to use this fix or to stay with OL 2.11 and the old
> solution. I mean, is it safe to use the fix, or better to wait until it is
> further developed?
> Thank you
> Benjamin
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/OL-2-12-and-Image-layer-flicker-tp4984910p4989578.html
> To unsubscribe from OL 2.12 and Image layer flicker, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4984910&code=dGVrbm9jcmVhdG9yQGdtYWlsLmNvbXw0OTg0OTEwfDEyMzgzMDYzOTQ=>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/OL-2-12-and-Image-layer-flicker-tp4984910p4990125.html
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120723/9f40944b/attachment.html>
