[OpenLayers-Users] How do I make the map static?
Marco Baumgärtner
kalleernst at googlemail.com
Tue Jul 31 00:07:39 PDT 2012
Using a smartphone(android) I cannot scroll down on the page containing
an almost full-screen map as moving the finger over the map makes the
map pan instead. Which is nice in general but not in this case. How do I
This is my code:
> <div style="width: 100%; height: 100%;" id="mapdiv">
> </div>
> <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
> <?php
> $bildn = "image.png";
> $gr = getimagesize($bildn); ?>
> <script>
> OpenLayers.Lang.setCode('de');
> map = new OpenLayers.Map("mapdiv");
> map.addLayer(new OpenLayers.Layer.OSM());
> projectTo = map.getProjectionObject();
> epsg4326 = new OpenLayers.Projection("EPSG:4326")
> var lonLat = new OpenLayers.LonLat( <?php echo $_GET['lon']; ?> ,
> <?php echo $_GET['lat']; ?> ).transform(epsg4326, projectTo);
> var zoom = <?php echo $radius; ?> ;
> map.setCenter(lonLat, zoom);
> var vectorLayer = new OpenLayers.Layer.Vector("Overlay");
> var feature = new OpenLayers.Feature.Vector(
> new OpenLayers.Geometry.Point( <?php echo $_GET['lon']; ?> , <?php
> echo $_GET['lat']; ?> ).transform(epsg4326, projectTo),
> description: 'Here'
> externalGraphic: '<?php echo $bildn; ?>',
> graphicHeight: <?php echo $gr[1]; ?> , graphicWidth: <?php echo
> $gr[0]; ?> , graphicXOffset: <?php echo - $gr[0] / 2; ?> ,
> graphicYOffset: <?php echo - $gr[1]; ?>
> vectorLayer.addFeatures(feature);
> map.addLayer(vectorLayer);
> //Add a selector control to the vectorLayer with popup functions
> var controls = {
> selector: new OpenLayers.Control.SelectFeature(vectorLayer,
> onSelect: createPopup,
> onUnselect: destroyPopup
> function createPopup(feature)
> feature.popup = new OpenLayers.Popup.FramedCloud("pop",
> feature.geometry.getBounds().getCenterLonLat(),
> null, '<div class="markerContent">' +
> feature.attributes.description + '</div>',
> null,
> true,
> function ()
> controls['selector'].unselectAll();
> //feature.popup.closeOnMove = true;
> map.addPopup(feature.popup);
> function destroyPopup(feature)
> feature.popup.destroy();
> feature.popup = null;
> map.addControl(controls['selector']);
> controls['selector'].activate();
> </script>
