[OpenLayers-Users] Spatial Filter DWITHIN unsuccessful
Neelima Emmani
neelima.emmani at iictechnologies.com
Tue Mar 6 01:00:50 EST 2012
Hi All,
I am working with openlayers , mapserver, postgis.
I have google map as a base map and overlayed few point layers. Now, i want to do filtering with respect to the path that's drew on the map. For this path , i am using draw feature with OpenLayers.Handler.Path. Upto here it is working fine. I can draw a line. Now using the line geometry , i am giving a spatial filter DWITHIN with a distance of 2000 and also mentioned distanceUnits as 'm'. After i draw a line , the spatial filter for DWITHIN gets activated and the layer to be filtered is completely disappearing. Now what i found is, it is throwing a WFS exception as below -
msWFSGetFeature(): WFS server error. Invalid or Unsupported FILTER in GetFeature :
(<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:And><ogc:DWithin><ogc:PropertyName>the_geom</ogc:PropertyName><gml:MultiLineString xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:900913"><gml:lineStringMember><gml:LineString><gml:coordinates decimal="." cs="," ts=" ">-79.205932617188,32.309033345029 -79.458618164063,32.267239420261 -79.851379394531,32.144067753448 -78.255615234375,33.130344611623</gml:coordinates></gml:LineString></gml:lineStringMember></gml:MultiLineString><ogc:Distance units="m">200000</ogc:Distance></ogc:DWithin><ogc:BBOX><ogc:PropertyName>the_geom</ogc:PropertyName><gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326"><gml:coordinates decimal="." cs="," ts=" ">-84.100341796875,29.910254
244941 -73.114013671875,34.556260876457</gml:coordinates></gml:Box></ogc:BBOX></ogc:And></ogc:Filter>
And then I checked with get Capabilities , It is spatial filter DWITHIN capable. After that I checked by copying my WFS layer url along with filter properties as below -
http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/openlayers-2.10/examples/us1gc09m-addline.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=us1gc09m&Filter=%3CFilter%3E%3CDWithin%3E%3CPropertyName%3Ethe_geom%3C/PropertyName%3E%3Cgml:Point%3E%3Cgml:coordinates%3E-80.22217%2031.07991%3C/gml:coordinates%3E%3C/gml:Point%3E%3CDistance%20units=%27m%27%3E100%3C/Distance%3E%3C/DWithin%3E%3C/Filter%3E
into a browser. With this, It works well. No exception is thrown and the query is done properly. So, now, i do not understand where is the problem lies.
Can any one tell me how to solve this. How to do Spatial filter DWITHIN. And is my approach right?
Below is my JS code ---
var map;
var spatialfilter;
function init() {
map = new OpenLayers.Map("map");
//GOOGLE MAP
var base = new OpenLayers.Layer.Google("Google Hybrid", {'type': G_HYBRID_MAP});
map.addLayer(base);
//CREATE WMS LAYER
var wms = new OpenLayers.Layer.WMS("wms", "http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/openlayers-2.10/examples/xyz.map",
{layers: 'xyz'}, {isBaseLayer: false, visibility: false, opacity: 0.5, singleTile: true});
map.addLayer(wms);
//VECTOR LAYER FOR PANEL
var vlayer = new OpenLayers.Layer.Vector("vlayer");
map.addLayer(vlayer);
// CREATE WFSLAYERS
//style map for points
var styleMap = new OpenLayers.StyleMap(OpenLayers.Util.applyDefaults({fillColor: "CYAN", fillOpacity: 1, strokeColor: "black"},
OpenLayers.Feature.Vector.style["default"]));
// mock up a protocol for synchronous and successful commits
var wfs_protocol = new OpenLayers.Protocol.WFS({url:"http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/openlayers-2.10/examples/xyz.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=xyz",
featureType: "xyz",
srsName: "EPSG:900913"});
var wfslayer = new OpenLayers.Layer.Vector("WFS", {styleMap: styleMap,
strategies: [new OpenLayers.Strategy.BBOX()],
protocol: wfs_protocol
map.addLayer(wfslayer);
map.addControl(new OpenLayers.Control.MousePosition());
map.addControl(new OpenLayers.Control.LayerSwitcher());
//MAP CONTROLS
var defStyle = {strokeColor: "red", strokeOpacity: "0.7", strokeWidth: 1, fillColor: "red", pointRadius: 3, cursor: "pointer"};
var sty = OpenLayers.Util.applyDefaults(defStyle, OpenLayers.Feature.Vector.style["default"]);
var DeleteFeature = OpenLayers.Class(OpenLayers.Control, {
initialize: function(layer, options) {
OpenLayers.Control.prototype.initialize.apply(this, [options]);
this.layer = layer;
this.handler = new OpenLayers.Handler.Feature(
this, layer, {click: this.clickFeature}
clickFeature: function(feature) {
// if feature doesn't have a fid, destroy it
if(feature.fid == undefined) {
this.layer.destroyFeatures([feature]);
} else {
feature.state = OpenLayers.State.DELETE;
this.layer.events.triggerEvent("afterfeaturemodified", {feature: feature});
feature.renderIntent = "select";
this.layer.drawFeature(feature);
setMap: function(map) {
this.handler.setMap(map);
OpenLayers.Control.prototype.setMap.apply(this, arguments);
CLASS_NAME: "OpenLayers.Control.DeleteFeature"
var panel = new OpenLayers.Control.Panel(
{'displayClass': 'customEditingToolbar'}
var navigate = new OpenLayers.Control.Navigation({
title: "Pan Map"
var drawpath = new OpenLayers.Control.DrawFeature(
vlayer, OpenLayers.Handler.Path,
title: "Draw Path",
displayClass: "olControlDrawFeaturePath",
multi: true
var drawpoint = new OpenLayers.Control.DrawFeature(
vlayer, OpenLayers.Handler.Point,
title: "Add Point",
displayClass: "olControlDrawFeaturePoint",
multi: true
var box = new OpenLayers.Control.DrawFeature(vlayer,
OpenLayers.Handler.RegularPolygon, {
handlerOptions: {
sides: 4,
irregular: true
title: "Box Feature Select",
displayClass: "olControlDrawFeatureBox"});
var edit = new OpenLayers.Control.ModifyFeature(vlayer, {
title: "Modify Feature",
displayClass: "olControlModifyFeature"
var del = new DeleteFeature(vlayer, {title: "Delete Feature"});
panel.addControls([navigate,del, edit, box, drawpoint, drawpath]);
panel.defaultControl = navigate;
map.addControl(panel);
panel.activate();
map.zoomToMaxExtent();
map.setCenter(new OpenLayers.LonLat(-82, 28),5);
vlayer.events.on({
beforefeatureadded: function(event) { //here also tried with featureadded
var geometry = event.feature.geometry;
alert(geometry);
wfslayer.filter = new OpenLayers.Filter.Spatial({
type: OpenLayers.Filter.Spatial.DWITHIN,
property: "the_geom",
value: event.feature.geometry,
distance: 200000,
distanceUnits: 'm'
wfslayer.refresh({force: true});
var style_green =
strokeColor: "#00FF00",
strokeOpacity: 0.7,
strokeWidth: 4,
graphicName: 'square',
fillColor: '#FF0000',
pointRadius: 5
vlayer.drawFeature(event.feature, style_green);
alert(wfslayer.filter.evaluate(event.feature));
return false;
With Regards,
Neelima Emmani
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120306/1ba05fe2/attachment-0001.html
