[OpenLayers-Users] Panel with Navigation control, mouse wheel
zoom deactivated
Armin Burger
armin.burger at gmx.net
Wed Mar 7 17:15:50 EST 2012
I found now a solution to remove this strange (but likely intended)
behaviour. In case some is interested:
The deactivation of the mouse wheel for all other controls in the panel
is caused by the deactivation in the Navigation.js -> deactivate()
function. If one removes/comments out there the line
this.handlers.wheel.deactivate();
the mouse wheel function is available also for the other panel tools. If
one wants to keep also the drag/pan function (useful for example for a
map identify tool), one can also remove or comment out the line
this.dragPan.deactivate();
I put everything outside in a function to overwrite the standard
Navigation behaviour, like
OpenLayers.Control.Navigation.prototype.deactivate = function() {
if (this.pinchZoom) {
this.pinchZoom.deactivate();
this.zoomBox.deactivate();
//this.dragPan.deactivate();
this.handlers.click.deactivate();
//this.handlers.wheel.deactivate();
return OpenLayers.Control.prototype.deactivate.apply(this,arguments);
So far at least I have not noticed negative side effects of this
modification.
armin
On 04/03/2012 18:59, Armin Burger wrote:
> Hi everybody
> I noticed that if I replace in the panel control the "MouseDefaults"
> control with the "Navigation" control then the default mouse operation
> for the mouse wheel (zoom in/out) is deactivated if any other tool than
> the Navigation (e.g. the zoom control) is active.
> If I switch back to using MouseDefaults instead, then everything is fine
> (but this control is marked as deprecated...). One can easily see this
> behaviour with the "panel.html" from the "examples" directory. Is this
> deactivated mouse wheel zoom an intended behaviour? I have not found any
> setting that would avoid this.
> Thx in advance for any help
> Armin
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
