[OpenLayers-Users] Slow speed in IE 7,8
Andreas Hocevar
ahocevar at opengeo.org
Fri Mar 9 15:11:26 EST 2012
So if you really want to dive into this, you have to identify what
makes your page sluggish. This starts with the JavaScript code outside
OpenLayers, and ends in the way you use OpenLayers. For the latter,
this list can help, but you have to explain more about what you do
with OpenLayers. Things like:
What kinds of layers do you use?
How many layers do you use?
How are these layers configured (buffer)?
And first of all:
What exactly is sluggish and how?
Andreas.
2012/3/9 Shin, Sanghee <endofcap at gmail.com>:
> Dear Andreas,
> I totally agree with you. The ultimate solution would be to have people upgrade to IE9.
> However around 40% of Korean people are still using IE 7, 8 and our client should consider these people. That's why I'm trying to find the solution, we'll put the notice recommending IE9, Safari or other browsers though.
> Sanghee
> 2012. 3. 9., 오전 12:50, Andreas Hocevar 작성:
>> I'm sure it's not the answer you want to hear, but the solution is to
>> have people upgrade to IE9 or any of the other modern browsers
>> available.
>> Andreas.
>> 2012/3/8 Shin, Sanghee <endofcap at gmail.com>:
>>> Dear all,
>>> We're currently carrying out a weather map service project.
>>> You can see this site here: http://203.247.66.248/COMIS4P/map/map.jsp
>>> In this site, users can overlay near realtime radar image, satellite image and other weather information over the map by checking the box. You can also try these functions by checking far left 2 layer controls, that look like '날씨정보', '동네예보'
>>> This site works fine in Safari, Fire Fox, Opera and Chrome except IE 7,8.
>>> The problem is that this site is sluggish when we're using IE7 or IE8.
>>> Any good idea or solutions how to speed up this site with IE7,8?
>>> With regards,
>>> Sanghee
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
> Users mailing list
Andreas Hocevar
