[OpenLayers-Users] Re: WMSGetFeatureInfo - slow response in IE8 and
9
teknocreator
teknocreator at gmail.com
Mon Mar 12 14:29:46 EDT 2012
Andreas,
I'm sorry, but I don't really understand how to carry out what you're
describing. I originally just specified <!DOCTYPE html> for the page and
the same thing occurs. I searched the mapserver code for GetFeatureInfo and
DOCTYPE and I couldn't easily see in the code where this might pertain to
getfeatureinfo, as in doesn't appear to be referring to a dtd when carrying
out the request. The only references to DOCTYPE are in formatting error
exceptions when the WMS request string isn't formatted properly.
I tried a suggestion from W3 about specifying a local area for the dtd.
Unfortunately, I'm unable to install Fiddler on this one machine I'm working
and will have to check later.
However, I also decided to debug within IE8 and there's a lengthy delay in
the OpenLayers code, XMLHttpRequest.js. It seems to loop at least 4 times
in
this._object.onreadystatechange = function() {
and on the 4th
the routine goes through:
if (oRequest.readyState == cXMLHttpRequest.DONE) {
// Free up queue
delete oRequest._data;
fCleanTransport(oRequest);
// BUGFIX: IE - memory leak in interrupted
if (bIE && bAsync)
window.detachEvent("onunload", fOnUnload);
// BUGFIX: Some browsers (Internet Explorer, Gecko) fire OPEN
readystate twice
if (nState != oRequest.readyState)
fReadyStateChange(oRequest);
When it hits fReadyStateChange(oRequest), this is where a delay occurs
before continuing onto the next statement.
After that delay, it moves onto:
nState = oRequest.readyState;
And returns the value from MapServer.
In Firefox and with Firebug,
is not even entered.
I'll still look at this from the MapServer point of view and perhaps check
about bypassing the dtd somehow. But, there looks to be a possible issue
with how this is being handled within OL.
Dave M
View this message in context: http://osgeo-org.1560.n6.nabble.com/WMSGetFeatureInfo-slow-response-in-IE8-and-9-tp4563627p4571106.html
