[OpenLayers-Users] [SOLVED] Re: WMSGetFeatureInfo - slow response
in IE8 and 9
teknocreator
teknocreator at gmail.com
Mon Mar 12 19:11:00 EDT 2012
[SOLVED] Chart one up to user configuration error here It really helps if
one doesn't copy the actual page <!DOCTYPE ... statement into MapServer's
header template file. For returns of text/html format type, the mapfile for
MapServer needs an html header, body, and footer file. These can be fairly
complex. However, all I wanted was basically:
<html> (header)
<body> (body)
value = [value_0]
</body>
</html> (footer)
These must have a MapServer template line at the beginning that's looks like
a comment but MapServer uses it to identify an html template file.
Unfortunately, in the header, I had for some STRANGE reason copied the
<!DOCTYPE line. I think because perhaps MapServer at first indicated it
didn't look like a MapServer template file when I didn't have the <!--
MapServer Template --> line at the beginning. So, I must've thought the
<!DOCTYPE... was was needed. I found out later that each part needs the
<!-- MapServer Template --> line and didn't take out the <!DOCTYPE line.
The requirement of <!-- MapServer Template --> wasn't directly pointed
out as being required and I found that piece of info elsewhere. But, since
I didn't take out the <!DOCTYPE line, it gave IE grief. Interesting that it
worked in Firefox and Chrome.
Now when I do the query in IE8, takes 3-4 seconds like it does in FF or
Chrome. So sorry bothering the list but at least folks know what not to do.
<quote author="teknocreator">
Andreas,
I'm sorry, but I don't really understand how to carry out what you're
describing. I originally just specified <!DOCTYPE html> for the page
and the same thing occurs. I searched the mapserver code for GetFeatureInfo
and DOCTYPE and I couldn't easily see in the code where this might pertain
to getfeatureinfo, as in doesn't appear to be referring to a dtd when
carrying out the request. The only references to DOCTYPE are in formatting
error exceptions when the WMS request string isn't formatted properly.
I tried a suggestion from W3 about specifying a local area for the dtd.
Unfortunately, I'm unable to install Fiddler on this one machine I'm working
and will have to check later.
However, I also decided to debug within IE8 and there's a lengthy delay in
the OpenLayers code, XMLHttpRequest.js. It seems to loop at least 4 times
in
this._object.onreadystatechange = function() {
and on the 4th
the routine goes through:
if (oRequest.readyState == cXMLHttpRequest.DONE) {
// Free up queue
delete oRequest._data;
fCleanTransport(oRequest);
// BUGFIX: IE - memory leak in interrupted
if (bIE && bAsync)
window.detachEvent("onunload", fOnUnload);
// BUGFIX: Some browsers (Internet Explorer, Gecko) fire OPEN
readystate twice
if (nState != oRequest.readyState)
fReadyStateChange(oRequest);
When it hits fReadyStateChange(oRequest), this is where a delay occurs
before continuing onto the next statement.
After that delay, it moves onto:
nState = oRequest.readyState;
And returns the value from MapServer.
In Firefox and with Firebug,
is not even entered.
I'll still look at this from the MapServer point of view and perhaps check
about bypassing the dtd somehow. But, there looks to be a possible issue
with how this is being handled within OL.
Dave M
Andreas,
in
and on the 4th
// Free up queue
if (bIE && bAsync)
readystate twice
Dave M
Andreas,
in
and on the 4th
// Free up queue
if (bIE && bAsync)
readystate twice
Dave M
Andreas,
in
and on the 4th
// Free up queue
if (bIE && bAsync)
readystate twice
Dave M
View this message in context: http://osgeo-org.1560.n6.nabble.com/SOLVED-WMSGetFeatureInfo-slow-response-in-IE8-and-9-tp4563627p4572125.html
