[OpenLayers-Users] Re: vector layer prevents map pan and drag
Andreas Hocevar ahocevar at opengeo.org
Wed Mar 14 03:12:57 EDT 2012
check your projection settings. If you still cannot figure things out,
post at least the snippets where you create the map and add your
layers.
It is definitely not an issue with handlers.
Andreas.
On Tue, Mar 13, 2012 at 3:06 PM, Mr. Puneet Kishor <punk.kish at gmail.com> wrote:
> On Mar 13, 2012, at 8:54 AM, dkm wrote:
>> Puneet Kishor wrote
>>> So, this must be something others have faced as well. I have a nice
>>> voronoi fishnet covering my map, but because the vector layer is listening
>>> for mouseovers and clicks (Control.SelectFeature), I can't pan and drag
>>> the map now.
>> There used to be an answer in the wiki :
>> http://trac.osgeo.org/openlayers/wiki/SelectFeatureControlMapDragIssues
>> But now the pointer is incorrect (404 / faq.openlayers.org). I'm also
>> looking for a workaround...
> Thanks. Seems like I can find a bunch of FAQs at http://trac.osgeo.org/openlayers/wiki/FrequentlyAskedQuestions#VectorRelatedQuestions but none that answer this specific question.
> Anyone? OL gurus, developers, mavens?
> Muchas dankes in advance.
> Puneet Kishor_______________________________________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
