[OpenLayers-Users] Re: vector layer prevents map pan and drag
Andreas Hocevar
ahocevar at opengeo.org
Wed Mar 14 04:12:37 EDT 2012
I think the original poster's issue must be a different one, since he
didn't seem to be happy with what he found in the link you had posted.
Marc, the issue you ran into is definitely there. And it could
probably be solved by using
https://github.com/openlayers/openlayers/pull/174 instead of a
SelectFeature control.
Andreas.
On Wed, Mar 14, 2012 at 8:18 AM, Marc <dkm+osgeo at kataplop.net> wrote:
> Andreas Hocevar wrote:
>> Hi,
>> check your projection settings. If you still cannot figure things out,
>> post at least the snippets where you create the map and add your
>> layers.
>> It is definitely not an issue with handlers.
> Hi !
> I'm not sure I understand your answer... The problem (at least, mine)
> is that when there is a vector feature somewhere above the map (with
> select control enabled on the vector layer), it is not possible to use
> its area to drag the map. The problem is even more problematic when the
> whole map is covered with vector features...
> You can see the problem here for example:
> http://airspace.kataplop.net/airspace/amap/
> click on "update visible airspace", then you are left only with a
> little area usable for dragging the map.
> Maybe I did not understand your answer correctly ?
> Thanks,
> Marc
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
