[OpenLayers-Users] Re: need a little help with this ( user input
& wfsprotocol.read )
Bartłomiej Burkot
pomiarowiec10 at poczta.onet.pl
Wed Mar 14 05:36:44 EDT 2012
You are right it is not allowed.
"ERROR: cannot use column references in default expression"
You must use update clouse:
alter yourtable add column additional_id int;
update yourtable set additional_id=id;
If you frequently update your table it is more usefull for you to use
trigger. Look for it in postgresql doc.
Bartlomiej
W dniu 2012-03-13 12:10, Diego M. pisze:
> *Thanks!
> yes you are right!
> but are you sure of this command ?
> i get syntax error near default.*
> View this message in context: http://osgeo-org.1560.n6.nabble.com/need-a-little-help-with-this-user-input-wfsprotocol-read-tp4468479p4573645.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
