[OpenLayers-Users] Missing tiles in OSM map
Alessandro Candini
candini at meeo.it
Tue Mar 13 08:52:58 EDT 2012
Hi list.
I produce tiles using mapnik (www.mapnik.org) and I use the following
map definition:
var map = new OpenLayers.Map({
div: "map",
allOverlays: true,
maxExtent: bounds,
projection: fromProj,
displayProjection: toProj,
allowSelection: true,
controls: [new OpenLayers.Control.PanZoomBar(), new
OpenLayers.Control.Navigation()],
var layer = new OpenLayers.Layer.OSM(
layer_dir,
"tiles/${z}/${x}/${y}.png",
{zoomLevels: maxZoom, zoomOffset: minZoom, resolutions: res}
map.addLayer(layer);
The problem is that I have a visualization issue in IE and Chrome: the
missing tiles are represented as pink squares.
Instead in Firefox the visualization is perfect because it simply uses
a white background when the tile is missing.
Is there a map or layer parameter to visualize as white the missing tiles?
Thanks in advance,
Alessandro
