[OpenLayers-Users] Re: vector layer prevents map pan and drag
Puneet Kishor
punk.kish at gmail.com
Wed Mar 14 10:20:22 EDT 2012
On Mar 14, 2012, at 8:34 AM, Tobias Reinicke wrote:
> Hi Puneet,
> This may not work for you;
> In your highlight and select Ctrl (if you have both), add a line like this
> selectCtrl.handlers.feature.stopDown = false;
> highlightCtrl.handlers.feature.stopDown = false;
> put them just before the map.addControl for both places.
> See if that works.
Thanks Toby. This did work very well. I don't know how you discovered this, but it would be nice to have it as part of the API docs.
> On 14 March 2012 13:29, Puneet Kishor <punk.kish at gmail.com> wrote:
>> On Mar 14, 2012, at 3:12 AM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>>> I think the original poster's issue must be a different one, since he
>>> didn't seem to be happy with what he found in the link you had posted.
>> The link leads to a 404.
>>> Marc, the issue you ran into is definitely there. And it could
>>> probably be solved by using
>>> https://github.com/openlayers/openlayers/pull/174 instead of a
>>> SelectFeature control.
>> Will try that as well as John's suggestion.
>>> Andreas.
>>> On Wed, Mar 14, 2012 at 8:18 AM, Marc <dkm+osgeo at kataplop.net> wrote:
>>>> Andreas Hocevar wrote:
>>>>> Hi,
>>>>> check your projection settings. If you still cannot figure things out,
>>>>> post at least the snippets where you create the map and add your
>>>>> layers.
>>>>> It is definitely not an issue with handlers.
>>>> Hi !
>>>> I'm not sure I understand your answer... The problem (at least, mine)
>>>> is that when there is a vector feature somewhere above the map (with
>>>> select control enabled on the vector layer), it is not possible to use
>>>> its area to drag the map. The problem is even more problematic when the
>>>> whole map is covered with vector features...
>>>> You can see the problem here for example:
>>>> http://airspace.kataplop.net/airspace/amap/
>>>> click on "update visible airspace", then you are left only with a
>>>> little area usable for dragging the map.
>>>> Maybe I did not understand your answer correctly ?
>>>> Thanks,
>>>> Marc
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>> Andreas Hocevar
>>> OpenGeo - http://opengeo.org/
>>> Expert service straight from the developers.
>>> Users mailing list
>> Users mailing list
