[OpenLayers-Users] Missing tiles in OSM map
Andreas Hocevar
ahocevar at opengeo.org
Wed Mar 14 10:21:40 EDT 2012
this no longer works with recent versions (master and upcoming 2.12).
Instead, just add the following to your application's css:
.olImageLoadError {
background-color: transparent !important;
If you want an image showing something like "No imagery for this
region at the current zoom level", you can also set a
background-image.
Andreas.
On Wed, Mar 14, 2012 at 3:14 PM, Alessandro Candini <candini at meeo.it> wrote:
> Ok, I solved this issue with the following lines:
> OpenLayers.Util.onImageLoadError = function() {
> this.src = "http://localhost/static/img/missingTile.png";
> Where missingTile.png is a completely transparent image of size 256x256.
> The visualization is now perfect on every browser, but using firebug on
> Firefox I see that every missing tile produces a 404 error anyway.
> Can this lead to performance issues and is it possible to avoid these calls?
>> Hi list.
>> I produce tiles using mapnik (www.mapnik.org) and I use the following map
>> definition:
>> var map = new OpenLayers.Map({
>> div: "map",
>> allOverlays: true,
>> maxExtent: bounds,
>> projection: fromProj,
>> displayProjection: toProj,
>> allowSelection: true,
>> controls: [new OpenLayers.Control.PanZoomBar(), new
>> OpenLayers.Control.Navigation()],
>> var layer = new OpenLayers.Layer.OSM(
>> layer_dir,
>> "tiles/${z}/${x}/${y}.png",
>> {zoomLevels: maxZoom, zoomOffset: minZoom, resolutions: res}
>> map.addLayer(layer);
>> The problem is that I have a visualization issue in IE and Chrome: the
>> missing tiles are represented as pink squares.
>> Instead in Firefox the visualization is perfect because it simply uses a
>> white background when the tile is missing.
>> Is there a map or layer parameter to visualize as white the missing tiles?
>> Thanks in advance,
>> Alessandro
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Alessandro Candini
> MEEO S.r.l.
> Via Saragat 9
> I-44122 Ferrara, Italy
> Tel: +39 0532 1861501
> Fax: +39 0532 1861637
> http://www.meeo.it
> "ATTENZIONE:le informazioni contenute in questo messaggio sono
> da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
> al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
> per errore è tenuto ad informare il mittente ed a rimuoverlo
> definitivamente da ogni supporto elettronico o cartaceo."
> "WARNING:This message contains confidential and/or proprietary
> information which may be subject to privilege or immunity and which
> is intended for use of its addressee only. Should you receive this
> message in error, you are kindly requested to inform the sender and
> to definitively remove it from any paper or electronic format."
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
