[OpenLayers-Users] resolution of map
Andreas Hocevar
ahocevar at opengeo.org
Fri Mar 16 09:19:47 EDT 2012
the default for the resolution at zoom level 0 is the map size in map
units (e.g. 360 degrees) divided by the default tile size (256
pixels). In your example, the 1st resolution is for zoom level 1.
Andreas.
On Fri, Mar 16, 2012 at 10:33 AM, truongxuan quang
<truongxuanquang at yahoo.com> wrote:
> Hello list
> There are someone could help me to write down here the equation of
> resolution, example in my case
> I use
> var bounds2 = new OpenLayers.Bounds(
> -180.0,-90.0,180.0,90.0 );
> with resolution as
> resolutions: [0.703125, 0.3515625, 0.17578125, 0.087890625, 0.0439453125,
> 0.02197265625, 0.010986328125, 0.0054931640625, 0.00274658203125,
> 0.001373291015625, 6.866455078125E-4, 3.4332275390625E-4,
> 1.71661376953125E-4, 8.58306884765625E-5, 4.291534423828125E-5,
> 2.1457672119140625E-5, 1.0728836059570312E-5, 5.364418029785156E-6,
> 2.682209014892578E-6, 1.341104507446289E-6, 6.705522537231445E-7,
> 3.3527612686157227E-7, 1.6763806343078613E-7, 8.381903171539307E-8,
> 4.190951585769653E-8, 2.0954757928848267E-8, 1.0477378964424133E-8],
> what about resolutions if I change Bounding Box to
> example new OpenLayers.Bounds(123,22,143,27)
> Thank you very much for your help
> All the best,
> Zuang
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
