[OpenLayers-Users] BBOX strategy with GeoJSON points
Puneet Kishor punk.kish at gmail.com
Fri Mar 16 16:23:36 EDT 2012
On Mar 16, 2012, at 3:13 PM, nguyenl wrote:
> Hi,
> I'm trying to configure openlayers to render a Vector layer of points.  The
> points are in GeoJSON format and are queried with Ajax using BBOX strategy.
> I've been trying to get it working, but can't find any examples on how to do
> this, and I haven't been able to get it thus far.
> Is this possible?
I just got this working a couple of days ago, and I am still mystified by at least one issue, but hopefully the following advice will get you started. See the code below --
	var vec = new OpenLayers.Layer.Vector(
		"My Vector Layer", {
			strategies: [new OpenLayers.Strategy.BBOX()],
			protocol: new OpenLayers.Protocol.HTTP({
	            url: "http://webserver/path/to/geojson.json",
	            params: {
					"a": "value of a",
					"b": function() {
						return a_value_for_b;
	            format: new OpenLayers.Format.GeoJSON()
	        styleMap: new OpenLayers.StyleMap({
	            "default": defaultStyle,
	            "select": selectStyle
The above code should just work. You can pass additional params to the query via the params key above. The only catch is, the data returned by the url has to be geojson at the root level. My data being returned is tucked inside a key. So, instead of getting back
	{a geojson packet}
I am getting
	{result:
		info: {
			value: "some value",
			array: ["some", "array"]
		geojson: {a geojson packet}
and I don't quite know where to intercept that and tell the layer that, hey, grab result.geojson to make the vector layer.
Puneet Kishor
