AW: [OpenLayers-Users] BBOX strategy with GeoJSON points
Arnd Wippermann
arnd.wippermann at web.de
Sat Mar 17 15:18:42 EDT 2012
Hi Puneet,
You can overwrite the read function of the format.
Then you should be able to grab the geojson from your response.
//function read from OpenLayers-2.11\lib\OpenLayers\Format\GeoJSON.js
function myReadFunction(json, type, filter)
type = (type) ? type : "FeatureCollection";
var results = null;
//instead
if (typeof json == "string") {
obj = OpenLayers.Format.JSON.prototype.read.apply(this,
[json, filter]);
} else {
obj = json;
//try this
var obj = eval('(' + json + ')').result.geojson;
//above no changes
if(!obj) {
OpenLayers.Console.error("Bad JSON: " + json);
} else if(typeof(obj.type) != "string") {
OpenLayers.Console.error("Bad GeoJSON - no type: " + json);
else if(this.isValidType(obj, type)) {
break;
return results;
var vec = new OpenLayers.Layer.Vector(
"My Vector Layer", {
strategies: [new OpenLayers.Strategy.BBOX()],
protocol: new OpenLayers.Protocol.HTTP({
url: "some_features.geojson",
params: {
"a": "value of a",
"b": function() {
return a_value_for_b;
format: new OpenLayers.Format.GeoJSON({read:myReadFunction})
map.addLayer(vec);
Arnd
