[OpenLayers-Users] Re: Weird issue with WFS-T
Tue Topholm tt at sugee.dk
Tue Mar 20 11:19:08 EDT 2012
I think I figured out when it happens, it the WFS-T layer is turned
off with setVisibility(false) from the start and you turn it on, then
it happens, but if the layer is turned on from the start there is no
issue.
Med venlig hilsen / Kind regards
Tue Topholm
Sugee
Tlf: +45 32 13 32 32
W: http://www.sugee.dk
18. mar. 2012 15.29 skrev Tue Topholm <tt at sugee.dk>:
> Yes, I will try to do it tomorrow....
> /Tue
> Den 18/03/2012 kl. 12.02 skrev Andreas Hocevar:
>> Can you share a minimal example that exposes the issue?
>> Thanks,
>> Andreas.
>> On Sun, Mar 18, 2012 at 1:47 AM, Tue Topholm <tt at sugee.dk> wrote:
>>> After some more testing, it seems to be in all the wfs-t implementations.
>>> Sometimes it gives wrong and the other times it goes bad.... any idea?
>>> Tue Topholm
>>> Sugee
>>> 16. mar. 2012 16.00 skrev Tue Topholm <tt at sugee.dk>:
>>>> I have tested a bit further....
>>>> It only applies to WFS 1.0.0
>>>> Tue Topholm
>>>> Sugee
>>>> 15. mar. 2012 18.12 skrev Tue Topholm <tt at sugee.dk>:
>>>>> Hi All
>>>>> I have a weird issue, the first time I send a UPDATE to the WFS-T the
>>>>> Geometry field is in WKT, but all the next requests are correct with
>>>>> GML, is there anyone that has tried that before?
>>>>> I'm using 2.11
>>>>> Here is the first request:
>>>>> <wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
>>>>> version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wfs
>>>>> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>>>>>        <wfs:Update typeName="gmgml:Sportsplæne"
>>>>> xmlns:gmgml="http://www.intergraph.com/geomedia/gml">
>>>>>                <wfs:Property>
>>>>>                        <wfs:Name>Geometry</wfs:Name>
>>>>>                        <wfs:Value>POLYGON((704544.36 6171349.62,704545.99
>>>>> 6171357.51,704547.8 6171365.23,704549.81 6171372.83,704552.01
>>>>> 6171380.37,704554.42 6171387.87,704557.03 6171395.32,704560.05
>>>>> 6171403.28,704563.81 6171411.85,704567.8 6171420.31,704571.95
>>>>> 6171428.55,704576.36 6171436.77,704580.38 6171443.86,704584.75
>>>>> 6171451.18,704589.03 6171457.98,704593.2 6171464.28,704596.13
>>>>> 6171468.48,704600.54 6171474.37,704604.81 6171479.75,704609.23
>>>>> 6171485.01,704614.44 6171490.9,704619.82 6171496.64,704625.35
>>>>> 6171502.24,704632.12 6171508.79,704638 6171514.2,704643.63
>>>>> 6171519.13,704649.37 6171523.92,704655.24 6171528.57,704661.22
>>>>> 6171533.06,704667.31 6171537.4,704673.26 6171541.38,704679.61
>>>>> 6171545.42,704686.07 6171549.29,704692.63 6171552.99,704699.28
>>>>> 6171556.53,704706.12 6171559.95,704712.96 6171563.15,704719.87
>>>>> 6171566.18,704726.86 6171569.03,704731.84 6171570.91,704733.66
>>>>> 6171571.59,704740.87 6171574.11,704747.76 6171576.62,704754.87
>>>>> 6171578.56,704762.19 6171580.54,704774.3 6171583.27,704778.96
>>>>> 6171585.88,704839.64 6171600.71,704976.32 6171634.38,704991.91
>>>>> 6171638.22,705061.63 6171655.36,705163.03 6171680.29,705203.54
>>>>> 6171690.43,705260.08 6171704.3,705298.29 6171713.57,705333.47
>>>>> 6171721.98,705349.64 6171725.68,705299.320787636
>>>>> 6171559.21622562,705024.521635147 6171396.7513163,704740.535274475
>>>>> 6171404.08322215,704544.36 6171349.62))</wfs:Value>
>>>>>                </wfs:Property>
>>>>>                <wfs:Property>
>>>>>                        <wfs:Name>ID</wfs:Name>
>>>>>                        <wfs:Value>339</wfs:Value>
>>>>>                </wfs:Property>
>>>>>                <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
>>>>>                        <ogc:FeatureId fid="Sportsplæne.339" />
>>>>>                </ogc:Filter>
>>>>>        </wfs:Update>
>>>>> </wfs:Transaction>
>>>>> And the next one looks like this:
>>>>>                <wfs:Property>
>>>>>                        <wfs:Value>
>>>>>                                <gml:Polygon xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:25832">
>>>>>                                        <gml:outerBoundaryIs>
>>>>>                                                <gml:LinearRing>
>>>>>                                                        <gml:coordinates decimal="." cs="," ts=" ">704544.36,6171349.62
>>>>> 704545.99,6171357.51 704547.8,6171365.23 704549.81,6171372.83
>>>>> 704552.01,6171380.37 704554.42,6171387.87 704557.03,6171395.32
>>>>> 704560.05,6171403.28 704563.81,6171411.85 704567.8,6171420.31
>>>>> 704571.95,6171428.55 704576.36,6171436.77 704580.38,6171443.86
>>>>> 704584.75,6171451.18 704589.03,6171457.98 704593.2,6171464.28
>>>>> 704596.13,6171468.48 704600.54,6171474.37 704604.81,6171479.75
>>>>> 704609.23,6171485.01 704614.44,6171490.9 704619.82,6171496.64
>>>>> 704625.35,6171502.24 704632.12,6171508.79 704638,6171514.2
>>>>> 704643.63,6171519.13 704649.37,6171523.92 704655.24,6171528.57
>>>>> 704661.22,6171533.06 704667.31,6171537.4 704673.26,6171541.38
>>>>> 704679.61,6171545.42 704686.07,6171549.29 704692.63,6171552.99
>>>>> 704699.28,6171556.53 704706.12,6171559.95 704712.96,6171563.15
>>>>> 704719.87,6171566.18 704726.86,6171569.03 704731.84,6171570.91
>>>>> 704733.66,6171571.59 704740.87,6171574.11 704747.76,6171576.62
>>>>> 704754.87,6171578.56 704762.19,6171580.54 704774.3,6171583.27
>>>>> 704778.96,6171585.88 704839.64,6171600.71 704976.32,6171634.38
>>>>> 704991.91,6171638.22 705061.63,6171655.36 705163.03,6171680.29
>>>>> 705203.54,6171690.43 705260.08,6171704.3 705298.29,6171713.57
>>>>> 705333.47,6171721.98 705349.64,6171725.68
>>>>> 705299.320787636,6171559.21622562 705024.521635147,6171396.7513163
>>>>> 704740.535274475,6171404.08322215
>>>>> 704544.36,6171349.62</gml:coordinates>
>>>>>                                                </gml:LinearRing>
>>>>>                                        </gml:outerBoundaryIs>
>>>>>                                </gml:Polygon>
>>>>>                        </wfs:Value>
>>>>>                </wfs:Property>
>>>>>                <wfs:Property>
>>>>>                </wfs:Property>
>>>>>                </ogc:Filter>
>>>>>        </wfs:Update>
>>>>> </wfs:Transaction>
>>>>> Tue Topholm
>>>>> Sugee
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
