[OpenLayers-Users] opacity slider for base layer
Robert Sanson
Robert.Sanson at asurequality.com
Wed Mar 28 17:17:26 EDT 2012
What you can do is create a simple rectangular polygon as an overlay
(covering your map extent), and give it a white colour and then set an
opacity on it. I have used this to dull down a bright base layer.
Robert
>>> Andreas Heckwolf <andreas.heckwolf at menturagroup.com> 29/03/2012
9:13 a.m. >>>
Hello,
thanks for the hint. I will have a look at that. The reason behind
this
is to make it easier to see and recognize other objects on the map.
Cheers,
Andreas
On Thu, 2012-03-29 at 08:58 +1300, Phil Scadden wrote:
> GeoExt has such beast, I suggest you look over their code. I am
little
> surprised at the idea of opacity on a baselayer. Opacity lets you
"see"
> through to lower layers but the baselayer is at the bottom already??
> Notice: This email and any attachments are confidential. If received
in error please destroy and immediately notify us. Do not copy or
disclose the contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
\_________________________________________________________________
Dipl.-Ing. Andreas Heckwolf Voice : +358 40 5847 445
Mentura Group Oy Fax: +358 424480 800
Lönnrotinkatu 32 A 26 00180 Helsinki www.menturagroup.com
Users mailing list
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
