[OpenLayers-Users] Catching WMS errors when using
OpenLayers.Layer.WMS... can it be done?
Paul Edwards
pjfingers at gmail.com
Wed May 2 17:05:50 EDT 2012
I posed this question a while ago, and having never received an answer I
came up with my own hackadelic solution. I post it now in case it helps
someone in the future. Prior to adding a layer to the map I generate an
AJAX call to retrieve a single tile (via a server-side proxy). I make sure
all the specific unique params that are going to be present in the
OpenLayers call are present in my test call. I then simply check the
result. If I get an image back I know the layer is good. If I get error XML
then I can review the error text and respond accordingly. If I get a server
error I know the layer itself is configured incorrectly and again I can
Here's the Layer code to perform the validation as I wrote it, and while
much of this is specific to our application the key bits are there if you
want them...
*The goal here is to determine if an externally sourced WMS layer is
functional. Disfunctionality
*could take the form of a down server, an invalid config, or a bogus
SLD.
validateExternalLayer: function(){
//some trickery to get the URL to test against
var op = this.getOpenLayersLayer(); //a fully instantiated
OpenLayers.Layer.WMS object
op.imageSize = new OpenLayers.Size( 256, 256 );
op.map = this.getOpenLayersMap();
var url = op.getURL( new OpenLayers.Bounds(-1,-1,1,1) );
//back em out, otherwise it will never be able to be added to the
map
op.imageSize = null;
op.map = null;
var isValid = false;
//for use within the ajax handlers
var exLayer = this;
$.ajax({
async: false,
timeout: 5000,
url: '/assets/php/requestProxy',
type: "POST",
data: {
url: url
complete: function( xhr, status ){
var statusCode = xhr.status;
var statusText = xhr.statusText;
var contentType = xhr.getResponseHeader( "Content-Type" );
var respText = xhr.responseText;
var layerName = exLayer.getLayerInfo().name;
if( statusCode != 200 ){
Ext.Msg.alert("Layer Error", "The <b>" + layerName +
"</b> layer cannot be properly loaded due to a server error. An error code
was returned of:<br>"+ statusCode + " - " + statusText + "<br><br>This
layer will be disabled.");
}else{
if( contentType == "text/html" ){
//This content type is returned when there is a PHP
error which is always a Server SLD configuration error
+ "</b> layer cannot be properly loaded due to a configuration
error.<br><br>This layer will be disabled.");
}else if( contentType.indexOf( "vnd.ogc.se_xml" ) != -1
//This content type is what the WMS server returns
error messages as
if( exLayer.getOpenLayersLayer().params.SLD ){
//WMS generated errors are fairly random and
non-specific. The only way to
//Conclusively determine if it's an SLD
problem vs something else is
//to try removing the custom SLD and validate
again... this usually fixes it
delete exLayer.getOpenLayersLayer().params.SLD
delete
exLayer.getOpenLayersLayer().params.LAYER_SLD
if( exLayer.validateExternalLayer() ){
//The issue is with the locally defined
SLD...
layerName + "</b> layer styles cannot be properly loaded due to a WMS
error. The WMS server returned:<br>'"+respText+"'<br><br>This custom
styling for this layer will be disabled.");
//Default back to the WMS provided legend
exLayer.contextMenu = null;
exLayer.getLayerInfo().useExternalLegend =
true;
isValid = true;
}//There is no 'else'. Since this segment
features a nested call the
//error message will be displayed in that inner
call
}else{
layerName + "</b> layer cannot be properly loaded due to a WMS error. The
WMS server returned:<br>'"+respText+"'<br><br>This layer will be
disabled.");
}else{
isValid = true;
return isValid;
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120502/5c699db2/attachment.html
