[OpenLayers-Users] How can I display each polygon in a different
color?
Markus
zielonka.markus at yahoo.de
Thu May 3 13:07:18 EDT 2012
Hello OpenLayers Team.
i have this Code dev. (Attachment).
How can I display each polygon in a different color?
map.addLayer(new OpenLayers.Layer.GML("OV's 2.000 Meter",
"2000meter.xml", { format: OpenLayers.Format.KML, projection:
map.displayProjection }));
map.addLayer(new OpenLayers.Layer.GML("OV's 4.000 Meter",
"4000meter.xml", { format: OpenLayers.Format.KML, projection:
First in Green
Second in Red
Search a good documentation and example. Found something but not help.
Thanks all.
Bye Markus
My Map online: http://www.meldekopf.de/osm/pn/map.html
<!-- Einbinden der OpenLayers & OpenStreetMap JS Dateien -->
<script src="http://www.openlayers.org/api/OpenLayers.js"></script>
<script src="http://www.openstreetmap.org/openlayers/OpenStreetMap.js"></script>
<!-- JS Code zum Erstellen einer OpenLayers Karte auf der Webseite -->
<script type="text/javascript">
var map;
function init(){
//Erstelle das OpenLayers Map Objekt
map = new OpenLayers.Map('map',
{ controls:[
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.Permalink(),
new OpenLayers.Control.LayerSwitcher()],
maxExtent: new OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
numZoomLevels: 19,
maxResolution: 156543.0399,
units: 'm',
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326")
//Hinzufuegen des Layerswitcher hinzu und aufklappen
var layerswitcher = new OpenLayers.Control.LayerSwitcher();
map.addControl(layerswitcher);
layerswitcher.maximizeControl();
//Hinzufuegen von Mapnik Layer als Standardkarte
var layerMapnik = new OpenLayers.Layer.OSM.Mapnik("Mapnik");
map.addLayers([layerMapnik]);
// TODO - Punkt 1
//Hinzufuegen der berechneten Erreichbarkeitspolygone (KML Files)
// Layername Pfad zur Dtei
map.addLayer(new OpenLayers.Layer.GML("OV's 2.000 Meter", "2000meter.xml", { format: OpenLayers.Format.KML, projection: map.displayProjection }));
map.addLayer(new OpenLayers.Layer.GML("OV's 4.000 Meter", "4000meter.xml", { format: OpenLayers.Format.KML, projection: map.displayProjection }));
map.addLayer(new OpenLayers.Layer.GML("OV's 6.000 Meter", "6000meter.xml", { format: OpenLayers.Format.KML, projection: map.displayProjection }));
map.addLayer(new OpenLayers.Layer.GML("OV's 8.000 Meter", "8000meter.xml", { format: OpenLayers.Format.KML, projection: map.displayProjection }));
map.addLayer(new OpenLayers.Layer.GML("OV's 10.000 Meter", "10000meter.xml", { format: OpenLayers.Format.KML, projection: map.displayProjection }));
// TODO - Punkt 2
//Hinzufuegen der Feuerwehrwachen als Layer
var firestations = new OpenLayers.Layer.GML("THW Ortsverbaende", "ortsverbaende.gpx", {
format: OpenLayers.Format.GPX,
style: {strokeColor: "red", strokeWidth: 5, strokeOpacity: 1, externalGraphic: "181px-THW.png", graphicWidth:31, graphicHeight:31},
map.addLayer(firestations);
// TODO - Punkt 3
// Zentrum der Karte. Die Position kann aus einem OSM Permalink
// entnommen werden: http://www.openstreetmap.org/?lat=50.08321&lon=8.24123&zoom=15&layers=M
var lat=50.733;
var lon=7.128;
var zoom=10;
var lonLat = new OpenLayers.LonLat(lon, lat).transform(map.displayProjection, map.projection);
if (!map.getCenter()){
map.setCenter (lonLat, zoom);
</script>
